Old 06-13-2017, 07:08 AM   #21
There Is No Substitute.
rick3000's Avatar
WOW!!!
Jager, your 986 looks amazing! Have you ever had it repainted? I don't see any paint imperfections or serious road rash, what's your secret? I can't wait to see what milestone you hit next, very impressive, and a great example of how proper maintenance affects longevity.
Old 06-13-2017, 09:38 AM   #22
What an impressive achievement!
I'm curious to know what your maintenance regimen has been, and what parts you've replaced either due to failure or preventatively other than the IMS. What about the AOS? Water pump?
Have you had the timing chain guides replaced at any point?
What oil/filter do you run, and how often are you changing it?
How hard do you drive it?
'02 Boxster S
'16 GTI PP
'17 Bolt (with a B)
Nmbrsix is offline   Reply With Quote
Old 06-13-2017, 10:35 AM   #23
If I remember correctly, Pedro posted a pic of his speedo and odometer as he hit 150k miles. His speedo was at 150 mph.
So we need a pic of your speedo at 300mph to keep up with Pedro.
Congrats. Keep it up. You are one of the stalwarts of the forum.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-13-2017, 06:01 PM   #24
Jager's Avatar
Jager, speaking about oil, do you know how much oil does your engine uses (about) every 1k miles? I am very curios due to the mileage on your car.
My car has 99k on the clock and it burns about one quart per thousand miles, and according to what I have read here, this oil consumption is kind of normal (no smoke through the tail pipe and have clean plugs..)
Regards!
It's using about 1/2 quart between oil changes, 4500 to 5000 miles.
Jäger
300K Mile Club
Old 06-13-2017, 06:08 PM   #25
Jager's Avatar
WOW!!!
It has not been repainted except for the front bumper cover. The front bumper cover was replaced when I hit a coyote a few years ago (there are posts about it on this forum). If you look closely the paint on the front cover it does not match exactly, but most people don't notice.
I hand wash with soft water and keep a good coat of wax on it, especially the front.
Jäger
300K Mile Club
Old 06-13-2017, 06:28 PM   #26
Jager's Avatar
Here is something I wrote a couple years ago that shows some of the maintenance:
Thinking of buying a Boxster? I have over 255,000 miles on my 2001 Boxster and can easily say it’s the best car I have ever owned. Not only is it a blast to drive (my daily driver) it’s the only car I have owned that has not left me stranded. I enjoy working on cars almost as much as driving them so that helps in keeping the cost of Porsche ownership down. There are routine items like changing the oil/filter, air filter, wipers, fuel filter, plugs, fan belt, and tires that I have done a number of times, but here is a list of other maintenance items I have done to my Boxster over the years (these are not necessarily in order but close):
Replaced windshield – Pro installed
Replaced rag top (cracked rear plastic window – don’t operate the top in cold weather) – Replaced myself
Replaced brakes and rotors – Myself
Replaced the battery -Myself
Replaced fuel pump (going bad) – Pro
Replace Air Oil Separator – Pro
Replaced the ignition switch -Pro
Replaced water pump (leaking) – Myself
Replace gas cap (seal cracked) – Myself
Replaced Air Oil Separator again (DO NOT OVERFILL MOTOR WITH OIL) - Myself
Replaced IMS Bearing, rear main seal, clutch, and the flywheel – Myself (210k miles)
Replaced all O2 sensors – Myself
Replaced front motor mount - Myself
Replace mass air flow sensor (no issues, now I have a spare) - Myself
Replaced all spark plug coils (no issues, preventative maintenance) - Myself
Replaced the seals on the oil cooler (no issues, preventative maintenance) - Myself
Replaced turn signal/cruise control switch group – Myself
Replaced headlights (entire assembly) – The plastic lenses had serous road rash after 200,000 miles
Replaced covers to the key fob remote controls - Myself
Replaced hood and trunk lift struts – Myself
Replaced the oil cooler and seals - Myself
Replaced driver’s side window regulator and locking switch – Myself
Replaced the front bumper (I hit a coyote) – Pro
Replaced the secondary air injection system cut-off valve, vacuum reservoir, electric cut-off switch – Myself
Replaced brake pads and rotors again @240k miles – myself
Replaced the rear track control arms- myself
Replaced the trailing arms - myself
Replaced the rear struts and top mounts – myself
Replaced IMS bearing at 243,000 miles with LNE bearing… Again.
Replaced water pump 243,000 miles
Replaced evaporator valves miles
Replaced rear wheel bearings 245,000 miles
Replaced both axles 245,000 miles
Replaced front wheel bearings 250,000 miles
Replaced catalytic converter (bank 2) 253,000 miles
Replaced AOS again 259.600 miles
My Boxster has the original motor, original muffler. No leaks and motor runs great.
It's my daily driver, I have taken to the track once, cross country twice, but mostly to and from work. I do like to get on it at least once or twice a day... I love to hear 5000 to 6000 RPM out of the motor.
Jäger
300K Mile Club
Old 06-14-2017, 08:42 AM   #27
Awesome. I also have a 01 base. Looking forward to the same mileage! Out of curiosity what was your build date and do you have single or double row IMS?
Old 06-14-2017, 09:34 AM   #28
JayG's Avatar
WooHoo!!!
your car looks great
So much for the nay sayers that say our cars are a POS
Old 06-14-2017, 05:39 PM   #29
Jager's Avatar
Build date is 06/01 and it has a single row IMS Bearing.
Jäger
300K Mile Club
Old 06-14-2017, 06:45 PM   #30
How are your camshaft deviation readings? Would you consider doing the chain guides yourself?
Sent from my SM-G930W8 using Tapatalk
newBgeek is online now   Reply With Quote
Old 06-14-2017, 07:29 PM   #31
Jager's Avatar
I need to take a look at the deviation... I have not looked for quite some time.
I would consider rebuilding the entire motor when it comes time. I have also considered getting another motor, while they are still available at reasonable prices.
Jäger
300K Mile Club
