Old 08-29-2019, 09:34 AM   #21
Try Woody (itsnotanova) or 40th St Auto Parts in Phoenix.
2001 Boxster
2007 Toyota Highlander
Old 08-30-2019, 12:46 PM   #22
I don't have one but expect to pay $100-200 for a factory cover when you find one.
Woody
Old 09-23-2020, 02:46 PM   #23
Coaster's Avatar
Correct, and Porsche went back to the rivets in 2005. 03/04 with no rivets is a bad idea. I put caulking under my 03/04 tail to keep the cover on. Still there after a year and several 100mph+ testing
Bumping an old thread. went to open my trunk and found the spoiler cap loose. Three of the 4 clips had failed. Age I suppose. Any suggestions for the caulk? Any long term considerations for using caulk? Like, will it be impossible to remove later? Or, does it impede access to anything else I might want to get to later?
New unpainted ones appear to run $150 to $180. If some silicon caulk does the trick might stick it back on - at least for a bit.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
Old 09-23-2020, 04:34 PM   #24
1998 Boxster Silver/Red
So they ran out of clips at your local dealer?
Caulk? It's not a Honda, Bruh.
Pay a visit to autozone... oreilly... they may have clips that will suit your need. Stay out of the caulk aisle.
1998 Porsche Boxster
Old 09-23-2020, 04:49 PM   #25
3M tape works too
Old 09-24-2020, 09:32 AM   #26
Will there be cake?
tonythetiger's Avatar
dont you need to remove the cap from time to time to remove rear bumber cover? You might just need to bite the bullet and replace, or use some high strength velcro, but not changing the hieght could be tough.
Old 09-24-2020, 10:30 AM   #27
Coaster's Avatar
The 03 clips are part of the formed part. To replace the clips you need a new part. Woody successfully locked his down with caulk. I'm not sure if you need to remove the cover to remove the rear bumper, anyone else know?
