Old 05-27-2017, 03:09 PM   #1
Another iPhone AUX question
Does anyone know if it is possible to swap out the 3.5mm cable for a iphone cable with the same blue connector on a CDR-220?
Also I am assuming charging is out of the question if it is possible?
Geoff
gpope is offline   Reply With Quote
Old 05-27-2017, 05:38 PM   #2
1999 base
Meir's Avatar
at some point i had the same thought myself.
i ended up installing a pioneer double DIN appradio, but these are the cables you will need to complete what you want.
https://www.amazon.com/AOAIS7505-Playback-Charging-Lightning-Connector/dp/B00KG5S7CC/ref=sr_1_3?ie=UTF8&qid=1495931037&sr=8-3&keywords=lightning+cable+to+rca
https://www.amazon.com/Porsche-1999-2002-Traffic-CDR-220-Coaster/dp/B012IVK5W6/ref=sr_1_fkmr1_4?ie=UTF8&qid=1495931143&sr=8-4-fkmr1&keywords=becker+connector+to+rca
https://www.amazon.com/Manhattan-inches-Stereo-Splitter-3-5mm-Adapter/dp/B0009JFF7A/ref=sr_1_1?ie=UTF8&qid=1495931503&sr=8-1&keywords=3.5+mm+female+to+rca+female+adapter
as mentioned, i never ended up using these cables, so i cannot testify how well it works.
you might also find it cheaper from other sources then amazon.
Old 05-27-2017, 09:20 PM   #3
There Is No Substitute.
rick3000's Avatar
After updating from 3.5mm, to iPod Dock Connector, to Lightning, I finally found an RCA to USB that also provides power (spliced into the phone connector under the dash). Now I can plug whatever I want into the USB and get audio and power. I think it is the best solution short of a new head unit.
My setup goes from the HU connector to RCA, to ground loop isolator to eliminate any hiss/whine, to this: PAC USB IS3301.
Don't be restricted to 3.5mm, an adapter to RCA is a common audio adapter you should be able to find at Best Buy, or RadioShack if you can find one. I think Home Depot might even have them.
Old 05-28-2017, 08:27 AM   #4
I purschase this item and it works well on my base boxster 1999
I needed to purschase an antenna adapter that did not come with the item.
iSimple Hands-Free Calling and Music Streaming Kit with Control Button for Smartphones - Frustration-Free Packaging - Black
CDNIcecube is offline   Reply With Quote
