Old 05-22-2017, 04:53 PM   #1
Oil level not readying on dipstick jimmy..
So i bought a 98 boxster out of a salvage yard last week. This car has sit for just over 12 years. The boxster was never parted out. Previous owner hit a fence and mashed the rh front. Not bad. My question is the engine oil was drained as all salvage yards do. So i called my local porsche dealer and got the specs and capacity. I added 6 qts of oil and it does not ready on the dipstick. so i added a couple more, still nothing. I know what your thinking look under the car, no i have. not sure what to do. I would like to try and fire this thing up, but unsure. Any suggestions?
1stbox is offline   Reply With Quote
Old 05-23-2017, 01:04 PM   #2
Xpit77's Avatar
Sometimes the dip stick tube breaks. The stick will go out the opening instead of going to were it is suppose to. This will show no oil. Look on the passenger side to see if it isn`t broken.Mine went through the hole and landed on the positive post on the starter.
Fortunately Woody had one in stock.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 05-23-2017, 02:55 PM   #3
RedTele58's Avatar
^^^ This
This happened this past summer to 78F350 (Jon) when he rescued the car that is now my Spec Boxster build. His solution after adding oil and it not showing on the dipstick was to check the dash display with the ignition turned to the first position. It showed full, and sure enough, he had to drain oil from the engine prior to starting.
Check the dash display before you go too far down the rabbit hole.
Old 05-23-2017, 01:08 PM   #4
POG champ, 1995.
Disregard, forgot about the oil level indicator on the dash. lol My bad.
1999 Boxster 2.5l 5-spd. 168k miles and climbing.
Build: http://986forum.com/forums/show-tell-gallery/63257-greta-not-really-build-so-much-maintenance-record-build-thread-w-bs.html
IG: @ryanjboutin
ryanjboutin is offline   Reply With Quote
