Old 05-17-2017, 02:53 PM   #1
Trunk Switch
I'm hoping someone can help, my rear trunk switch is pushed into the plastic side cover, i'm hoping someone can tell me hoe to remove that cover as I've looked at it and it's on there really snug. Is it as simple as using a trim tool to pop out the two trim plughs at the front of the cover?
Tuffty_Nut is offline   Reply With Quote
Old 05-17-2017, 03:08 PM   #2
1999 base
Meir's Avatar
No.
you need to remove two plastic cups from the side of the panel.
then insert a 5mm Allen key. do not remove the bolts completely, just turn it few turns.
now you are ready to pull the panel up.
let me see if i have some pics.
Old 05-17-2017, 03:11 PM   #3
No.
Fantastic, that's just what i needed to know. Thank you.
Old 05-17-2017, 03:30 PM   #4
1999 base
Meir's Avatar
here you go:
Old 05-17-2017, 04:27 PM   #5
Perfect, thank you very much.
