Old 05-11-2017, 11:31 PM   #1
PCM question
Hello team, does a pcm unit from a 2002 boxster work with the factory harness in a 2000 boxster?
986patrick is offline   Reply With Quote
Old 05-12-2017, 12:40 AM   #2
Yes, once the DME is programmed to the car. You can't just pop it in and expect it to work if that's what you're asking?
Woody
Old 05-12-2017, 04:50 AM   #3
I would also be concerned about the 2002 use of CAN Bus, which the 2000 did not have.
Old 05-12-2017, 06:40 AM   #4
Chuck W.'s Avatar
Man, I wish I had known that. I had bought a unit awhile back and could not get it to work in my Boxster. I just wanted to use the head unit, not the navigation driver. My bad for not asking an expert!
CAN Bus didn't start until 2003 MY.
1995 Porsche C4 Cab
Old 05-12-2017, 08:17 AM   #5
Really? My 2001 has CAN Bus................
Old 05-12-2017, 02:49 PM   #6
I am guessing this is something the dealer needs to do/charge for?
Old 05-12-2017, 03:19 PM   #7
You need someone with either a PST II or a PIWIS system to code the car for the PCM to work.
Old 05-12-2017, 04:09 PM   #8
Porsche "Purist"
Paul's Avatar
And you will need to ask your dealer to provide the learning codes (passwords).
1987 924S. 2002 996TT. PST-2
Old 05-13-2017, 07:44 PM   #9
GTA_G20's Avatar
Pretty sure 2002 has partial can bus....
GTA_G20 is offline   Reply With Quote
