Old 05-03-2017, 12:31 PM   #1
On the slippery slope
JayG's Avatar
Wheels can be repaired. Its not a DIY, you want to go to a place that specializes in wheel repair.
They can fix cracks and bends.
That being said, I probably would not want to uses repaired wheels on the track. Far too many other things can go wrong and why take more chances than you needs to. For DD, a different story. Far less stress than on the track. I noticed a small crack on the outside edge and it did not go completely through. I had it repaired and no issues or problems. They are my DD wheels
It must have happened hitting a pot hole (thank you CalTrans!). The wheel repair shop also noticed it was slightly bent and fixed that as well.
Keep an eye out online on forums and gasp, craigslist. I bought both sets of my track/AX wheels that way. I paid $350 for one set including new HTR ZIII tires and $200 for the other set. No need to spend $1000's on used wheels.
Also check your local PCA chapter's classifieds. Some great deals there too
2004 996 Targa Tip
Instructor - San Diego region
Old 05-03-2017, 01:31 PM   #2
djw8282's Avatar
That being said, I probably would not want to uses repaired wheels on the track. Far too many other hings can go wrong and why take more chances than you needs to. For DD, a different story. Far less stress than on the track. I noticed a small crack on the outside edge and it did not go completely through. I had it repaired and no issues or problems. They are my DD wheels
It must have happened hitting a pot hole (thank you CalTrans!). The wheel repair shop also notices it was slightly bent and fixed that as well.
Thanks Jay. I'm still searching!
djw8282 is offline   Reply With Quote
