Old 04-16-2017, 10:14 AM   #1
LEJ
Fault code help needed
Hi, I had the check engine light come on while on the freeway. When I checked via my Durametric it came up with 2 codes: P0420 and P0430 Both say "Short to B+/upper limit/rich mixture Threshold"
Any idea's on how I solve the problem will be greatly appreciated as I haven't a clue as to where to start looking to solve the problem/s.
thanks
Larry
Current vehicle - -2001 Boxster S, (sadly all of the following cars are gone) 1973 911T with 3.2 engine, 2002 911, 1975 911S, 1971 911T, 1968 912
LEJ is offline   Reply With Quote
Old 04-16-2017, 10:39 AM   #2
Might want to look here to give you a place to start diagnosis.
https://www.discountconverter.com/catalytic_converters_news/news_page.cfm?Key=catalytic_converter-&News=120
pomerlo is offline   Reply With Quote
Old 04-16-2017, 10:47 AM   #3
LEJ
WOW,, Thank you. That was a bunch of good info
thanks again
Old 04-16-2017, 10:51 AM   #4
LEJ - seems like you may need a recommendation for a competent ,honest Indie?Local Forum members are a good source of such.Maybe start a new Thread asking that specific question?
Meanwhile the usual suspects are MAF and both O2 sensors.
The Maf is easy to clean.Worth trying
The O2 sensors - monitor their voltage and watch the RKAT/FRA
While you are 'in there' check coils and plugs ?
A good Tech would be able to diagnose the problem very quickly -don't clear the codes !
None of these parts are expensive/difficult to fit but specifying the correct part number is tricky.You need to be very specific with Model/engine size/VIN.
Pomerlo - that was a great link - thank you !
Let us know what happens?
Old 04-16-2017, 11:18 AM   #5
LEJ
Gelbster, thanks for the info. I replaced all 4 O2 sensors and spark plugs less than 2,000 miles ago. I'll give the MAF a good cleaning but the info provided by POMERLO also indicates it could be the Catalytic converter. Further info:: Idle is spot on and no loss of power.
If I need a repair shop, I always go to Precision Motion in Riverside. Great guys and they do excellent work.
Old 04-16-2017, 01:13 PM   #6
Pomerlo gave you the best link!
Info by drip feed :-) ?
O.k. -with the new info - different suggestion.
Clean the MAF, do clear the codes and drive a little (to Riverside?) to see if they return .Let PreMo do the O2 Voltage observations, FRA & RKAT. But take the part numbers of all the items you replaced (see my previous post) RND Euro Parts have a reliable site for checking correct part numbers
PreMo will quickly tell you if it is O2 Sensor failure or Cats.
Look carefully at The MAF -does it have a droopy 'nose' ? Look at parts photos to see what I mean. The old part is different.The correct one varies by age/model and to use the new MAF you may need a reflash for the later MAF.There is a TSB but PreMo will do that if necessary.
Tell them if you are using a K&N air filter & have recently oiled it.
Mention any change in Oil Consumption.overfilling of oil, ,Tracking/wild driving/AOS failure.
Old 04-16-2017, 02:34 PM   #7
LEJ
The only codes were P0420 and P0430 and according to my the code chart they both read: "Short to B+/upper limit/rich mixture Threshold"
Idle is great, no loss of power, no misfiring that I know of. At 62,000 I had the IMS, clutch, motor mount and coolant bottle replaced, at that time Precision Motion checked the AOS and it had been replaced and was in good condition. I do use a K&N but it's been 2,000 miles since I cleaned and oiled it.
Like I said in the above post, (4) new O2 sensors, 6 new spark plugs at 62,000 miles No oil burning, no excessive oil consumption no overly wild driving (I think?)
Old 04-16-2017, 03:37 PM   #8
The oily K&N is a potential problem for the MAF among other things - Search for the negative details.
Obviously there are more serious issues covered previously.
Old 04-23-2017, 08:38 PM   #9
LEJ
Update:
As I mentioned in a previous post, I do have a K&N so, I pulled the Mass Air Flow Sensor and used an aerosol can of MAF cleaner and gave it a bath. Not much there to see so no evidence of oil but that doesn't mean anything. Anyway the bottom line is I put about a 100 or more miles on the car trying to replicate when the Check engine light came on. So far, no Check Engine light and hopefully that was the problem.
Old 04-24-2017, 06:55 AM   #10
Any K&N oil residue upstream of the MAF potentially provides a reservoir for future MAF-related codes - long after you switch back to a dry filter.
Old 04-24-2017, 08:28 AM   #11
1997 Tip, 2018 Macan
rexcramer's Avatar
+1 for Precision Motion.
