Old 06-28-2006, 02:05 PM   #1
lug nuts question and a couple other ones
Hi I'm new here. Some good info just reading some posts. I just have a couple questions.
I have a 2001 Boxster S and I don't have a tool kit is that an option or is it hidden somewhere?
Also where is the tire jack?
If I take off one lug nut and replace the same lug nut do I have to use the jack?
Finally does anybody know a good place to get repacement center caps, lug nuts and stem caps?
Thanks...
robgusto is offline   Reply With Quote
Old 06-28-2006, 02:31 PM   #2
Jack and tools should be behind the spare tire...
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 06-28-2006, 06:52 PM   #3
if your really missing your tool kit, like i did, just get them on ebay...much cheaper than buying them from porsche. I got mine for around $90 for the complete kit. Hope this helps.
http://i46.photobucket.com/albums/f1...i-IMG_2016.jpg
Engineered to Outperform!
986 silver boxster
E46 TiAg ///M3
92 red miata
boxsterx is offline   Reply With Quote
Old 06-28-2006, 06:54 PM   #4
Replacing one lug nut without jacking the car should not be a problem.
Norminhouston is offline   Reply With Quote
Old 06-29-2006, 08:38 AM   #5
thank you
thanks, I did find the tool kit and jack behind the tire. I think I will replace the rusted lug nuts/bolts when I get new tires. Thanks again for your help.
Old 06-29-2006, 08:44 AM   #6
Rob,
The place you take to replace your tires won't have Porsche lug nuts, as they are unique to Porsches (read: more expensive). Actually, they are remarkably durable bolts, as they withstand 96 ft/lbs of torque with a length of only 45mm. You can get the replacement OEM ones here - http://www.epiqautosport.com/mode/products/prid/106/1137 - or pick up some chrome versions as well. Alternatively, you can just clean and paint your existing ones...
Todd
2005 Boxster S - Atlas Grey/Black, PASM, Sport Chrono, Bose
2006 Infiniti M35 Sport
2007 Cadillac Escalade (tow vehicle with bling)
'00 Boxster - 2.7l w/FVD ECU tuning, Moton double adjustable suspension, custom stainless headers, lightweight flywheel, dual Magnaflow mufflers, 18" CCR wheels, 911 front brakes in front, Boxster front brakes in rear, full welded cage.
http://www.epiqautosport.com/images/epiqtoddavatar2.jpg
EPIQTodd is offline   Reply With Quote
Old 06-30-2006, 08:41 AM   #7
Buy an owner's manual off of Ebay if you can. It's actually pretty helpful in getting to know your car...
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
denverpete is offline   Reply With Quote
Old 06-30-2006, 01:31 PM   #8
I think I will paint my lug bolts. Can anyone recommend a durable paint that will withstand the pressures of a lug wrench?
