Old 03-29-2017, 03:42 PM   #1
Exhaust pops and crackles
Hi friends, i've a problem please help me...
When i start the car, and the engine is cold, the Exhaust makes some pops and crackles, then when the engine becomes hot the problem seems to disappear.
I've read something about it, and today i remove and clean the Throttle Body and MAF Sensor (CRC maf sensor spray) following this guide: https://www.youtube.com/watch?v=slPzoplzWT0&t=71s
After re-mounting all the problem seems to be less but not disappeared.
So i decided to order, according to this guide (Porsche Boxster Mass Air Flow Sensor (MAF) Replacement and Troubleshooting - 986 / 987 (1997-08) - Pelican Parts Technical Article), to buy a new MAF sensor with the same code of mine 996.606.124.00 (i've a 1999 Boxster S).
It could be the MAF?
Another symptom detected after an aggressive driving is that the TC LED turns on (goes in failure)...it can be that the ECU is not being able to manage MAF (damaged??)
Reading the ECU with my bluethoot sanp-in and Torque no errors where find.
It could be lambda probe?
it could be the ignition coils or spark plugs (may be never changed)?
Please tell me some about it, and excuse me for my bad english...
A.
Hi, i'm Antonio from Italy.
Boxter 986 S Year: 1999
alcubot is offline   Reply With Quote
Old 03-30-2017, 04:00 AM   #2
anyone can help me?
Old 03-30-2017, 04:05 AM   #3
07 Carrera S Cab
Boxtaboy's Avatar
Most people like the sound of pops and crackles in their exhausts. Lol. Is there anything else wrong with the car? Is the engine behaving strangely otherwise when driving? Not sure why you are getting a TC light. Maybe someone else here can help.
Old 03-30-2017, 06:39 AM   #4
2003 S, Arctic Silver, M6
paulofto's Avatar
Antonio, please make a recording of the sounds you hear. They are likely perfectly normal but if we could hear them we might be able to tell you if they are not.
Old 03-30-2017, 06:59 AM   #5
DrCactus's Avatar
I had the same thing but turned out I had a bracket broken/loose which caused the rattle noise ... make sure everything is tight and secure
DrCactus
Old 03-30-2017, 02:28 PM   #6
in this days i'll make a video\audio, meanwhile some opinions to help me?
Old 03-30-2017, 05:00 PM   #7
Artist, 986S tinkerer
NewArt's Avatar
Generally when there are engine malfuncions, there are codes generated. Please get the codes read and we can probably help you. Otherwise, it's just guesswork.
Old 03-31-2017, 04:02 AM   #8
Reading the ECU with my bluethoot sanp-in and Torque no errors where finded....
Old 04-03-2017, 11:31 PM   #9
Solved!...it was the maf..:ah::ah:
With the new, non more exhaust pops and crackles...
Old 04-04-2017, 03:22 AM   #10
DrCactus's Avatar
alcubot - What did you change to solve the problem exactly? Cost? Parts? How was the MAF causing the issue?
DrCactus
