Old 03-28-2017, 09:50 AM   #1
Led tail lights
Recently purchased led tail lights for me 2000 Boxster, load resistors were included, as well as 1157 male adapters. when I supply 12 volt current from test/power wire, all lights work fine, but when I install them on car and connect power,nothing works. (yes, I have the key switched on). Any ideas ?????
Upland54 is offline   Reply With Quote
Old 03-28-2017, 01:18 PM   #2
Oldcarguy's Avatar
Be sure to confirm the polarity is correct. From my bike experience LEDs will not work with the polarity reversed.
Rgds, Fred
Old 03-28-2017, 01:24 PM   #3
+1 for polarity...
If your the one who inserted the bulbs/LED in the tailight, keep in mind pins cannot be inserted in any direction like a conventional bulbs.
pomerlo is offline   Reply With Quote
Old 03-28-2017, 02:30 PM   #4
On the slippery slope
JayG's Avatar
Porsche in their infinite wisdom has the center pin as ground and the case as +12v, so unless the LED is reverse wired, it won't work
This has been discussed in many threads
the search function is your friend
Might be nice to introduce yourself to the forum (not in this thread)
And without pictures, It ain't real
2004 996 Targa Tip
Instructor - San Diego region
Old 03-28-2017, 04:22 PM   #5
With some LEDs reverse polarity kills them. Cjheck that they still work by applying 12V to them with the correct polarity.
1941 Dodge Luxury Liner Coupe
Old 03-28-2017, 04:51 PM   #6
JayG's Avatar
reverse polarity should not harm them as they are diodes which by nature block reverse voltage
2004 996 Targa Tip
