Old 03-15-2017, 12:07 PM   #1
Clutch Cylnder Slave Sleeve
I am getting fluid (brake/hydraulic) from a small hose on the right (passenger) rear side. Not from the brakes. Is the tube coming from the slave sleeve. No issues driving. It looks like it is coming from a the transmission.. does the slave cylinder have a drain tube?
Keith box 02 is offline   Reply With Quote
Old 03-15-2017, 12:41 PM   #2
No, the clutch slave is a closed system, just like the brakes.
Old 03-15-2017, 01:13 PM   #3
Are you absolutely certain it's not antifreeze?
Need_for_speed is offline   Reply With Quote
Old 03-15-2017, 03:34 PM   #4
Clutch slave cylnder
Dumb butt I guess I did not know the radiator fluid was clear. What should I check?
Old 03-15-2017, 05:11 PM   #5
Porsche "Purist"
Paul's Avatar
Wipe up the fluid with a white paper towel and verify its color.
1987 924S. 2002 996TT. PST-2
Old 03-15-2017, 05:33 PM   #6
There is a coolant overflow tube right in front of the rear tire on the passenger side. One of the more common conditions that would cause coolant to overflow is air in the cooling system, usually from an insufficient bleed. Have you had a coolant system flush recently? Do you have a CEL? Is the car overheating?
Old 03-16-2017, 08:26 AM   #7
thanks all it was coolant....
