Old 03-26-2017, 09:01 PM   #21
Yeah, I've read that article a few times but I still had a few doubts that you just cleared up. Thank you!
Javi Cooper is offline   Reply With Quote
Old 03-28-2017, 04:56 PM   #22
Damn Yankee
TeamOxford's Avatar
Received the rings a few days ago. As Chuck noted, they are not perfect, but pretty close. I had to use my Dremel on one of the rings to ensure a proper fit.
Sure makes a big difference aesthetically. Me like.
Just sayin'............
TO
Old 03-29-2017, 12:02 PM   #23
Hello all
Thank you very much for every feedback and suggestions.
We try to produce with the greatest accuracy.
Here even 1 millimeter, it makes a huge difference
There is a minimum size difference (indicators)
We had to make "optimum dimensions" for both versions
That is why it can happen, in one case they will fit perfectly.
In another it's minimal cramped.
Counter indicator - visually identical.
But they have minimal dimensional differences.
I think that although it is somewhat understandable, my text.
I use translator
I greet all users
Dido Tuning
Dido Tuning is offline   Reply With Quote
Old 04-01-2017, 02:10 PM   #24
Originally Posted by Dido Tuning View Post
Hello all
I use translator
I greet all users
Dido Tuning
Hi Robert!
I did have to trim about 1mm off of each side ring for them to fit, but it took less than 5 minutes. I used a Dremel and cutoff wheel, though I did not cut, just lightly pressed the end of the ring against the spinning face of the cutoff wheel. It would be easy enough to do with sandpaper, also.
I really like the way they snap in. Very easy install
Matte finish (AKA brushed aluminum):
They look great! Very pleased!
Old 04-02-2017, 12:03 AM   #25
Hello Friend.
thank you very much.
Robert Dido Tuning
Old 04-02-2017, 05:24 AM   #26
Giller's Avatar
Can't wait till there are ones available for the 987.2!
Old 04-02-2017, 08:51 AM   #27
We are very happy to produce (987)
Problem with front counter part (model)
Old 04-02-2017, 10:05 AM   #28
Giller's Avatar
Let me know if you get some 987.2 rings, I'll take a set!
Old 04-02-2017, 12:31 PM   #29
https://zapodaj.net/68123203d4d7f.jpg.html
Hello Friend.
Is this exactly the counter?
Old 07-27-2017, 04:32 AM   #30
mikesz's Avatar
Hi Chuck, thanks for posting. I have a set on order! polished of course! I don't think Fred appreciates the Chrysler letter cars! LOL!
99 Porsche Boxster
Old 07-27-2017, 10:23 AM   #31
Chuck W.'s Avatar
Cool. Ha, you're right. But then it might be a generational think.
1995 Porsche C4 Cab
Old 07-30-2017, 06:59 AM   #32
mikesz's Avatar
Hi Chuck! I have to tell you many thanks for the tip regarding the trim rings! I have 996 gauges in my 99 but I have C4 gauges that were modified by Steve Eiche "Qumulus". You had told me about him a couple years ago but I wanted the trim rings and could not find them. I was about to give up when I saw your post. And thanks for the 4 stalk!
99 Porsche Boxster
Old 07-30-2017, 08:34 AM   #33
oldskool73's Avatar
I've also added these and they look great. Also want to add that Robert the seller is great too, I managed to mangle one of mine while fitting them and he video chatted with me on facebook to explain the fitting then sent me a replacement half way round the world for free! Would recommend!
oldskool73 is offline   Reply With Quote
