Old 03-07-2017, 10:54 AM   #1
4 Stalk Question
Hi guys - I have a base 02 Boxster that did not come with intermittent wipers nor cruise control. I'd really enjoy them both! There is a forum member who is currently selling a 4 stalk and it got me wondering if by merely installing a 4 stalk, would I be able to add cruise and int wipers to my car? I am guessing there is a lot more to it then just adding the 4 stalk and I was hoping that you guys could enlighten me please. I am a weak DIY guy, but, if its not too hard, maybe I could give it a try?? Your thoughts please.
Thanks for your time.
David Preston
2008 Cayman S
por356c is offline   Reply With Quote
Old 03-07-2017, 11:42 AM   #2
BirdDog's Avatar
David:
Ok, to see what's required, check out this pelican parts article (it's also available in the 101 Boxster projects book):
Porsche Boxster Cruise Control Installation - 986 / 987 (1997-08) - Pelican Parts Technical Article
With a 4-stalk, you can also add OBC (on-board computer):
Forum member pdwight had some excellent harnesses for the OBC upgrade, he might also have pre-made harnesses for the cruise upgrade.
Not sure what else you would need for the intermittent wipers... (others will probably chime in)...
Old 03-07-2017, 11:43 AM   #3
Multi-Boxer Driver
Deserion's Avatar
Adding the 4-stalk wouldn't add the variable intermittent wipers. That can be done by changing the wiper relay and connecting it to the rheostat (that would sit in the round cutout opposite the cigarette lighter).
As for cruise, I believe that connecting the stalk and having the cluster coded to enable it would do what you want (I'm not well-versed on adding this).
You also can add the OBC with the 4-stalk and have it enabled at the same time as cruise.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 03-07-2017, 01:18 PM   #4
Read the Pelican articles....the different years have different ECU/Cluster coding/wiring requirements. Durametric can code the OBC but cannot code the cruise (unless you have the pro version)
Old 03-07-2017, 02:47 PM   #5
Need For Speed
KRAM36's Avatar
Go on eBay and get the 4 stalk column. I got mine in perfect condition for $199.99 shipped and bought pdwight wiring harnesses. I think his price is too much personally. I'd give him $225 max.
As Deserion said, this will not add intermittent variable wiper timing, that is controlled from a dashboard knob. You will need to use a Durametric to turn on the OBC features or take it to a dealer to turn them on.
2003 Boxster S
Old 03-07-2017, 04:19 PM   #6
4 Stalk
Thanks everyone. Your comments have certainly pointed me in right direction. Now I understand this much better. I also found some previous threads that I did not find in my first search. You guys are the best!
David Preston
2008 Cayman S
Old 03-07-2017, 04:53 PM   #7
oldskool73's Avatar
You might want to try this for the wipers, easy and cheap...
Adding variable intermittent wipers on an early box, the easy way
oldskool73 is offline   Reply With Quote
