Old 02-23-2017, 01:51 AM   #1
hood and rear window
Friends, what procedure \ products you use to wash the canopy hood?
To rejuvenate the plastic rear window of the same (minimally yellowed) I saw that there are specific products, what do you advise?
Thanks in advance
A.
Hi, i'm Antonio from Italy.
Boxter 986 S Year: 1999
alcubot is offline   Reply With Quote
Old 02-23-2017, 08:01 AM   #2
I'm assuming by hood you are referring to the convertible top? For the most part I use only water and a soft brush to loosen the dirt. If it is very dirty/discolored I use mild car wash soap. If the water does not bead I reapply porsche convertable top conditioner to waterproof. For the plastic window I used meguires plastix
Sent from my SAMSUNG-SM-N920A using Tapatalk
mmassey0125 is offline   Reply With Quote
Old 02-23-2017, 08:26 AM   #3
oldskool73's Avatar
I use the 303 convertible top cleaner and a soft brush, then follow up with the 303 fabric guard. Cleaner works ok, and the water beading lasts ages.
oldskool73 is offline   Reply With Quote
Old 02-23-2017, 05:56 PM   #4
Lew
So Blessed!
Lew's Avatar
I wondered how it's used and how good it works....might give it a try!
https://smedia.webcollage.net/rwvfp/wc/cp/22611247/module/cpwalmart/_cp/products/1473794105238/tab-00daffdb-dd06-4364-ab9a-bd3225698061/3a73a583-5809-48c8-9c10-f9806823c64e.mov.mp4full.mp4
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
