02-08-2017, 01:59 PM
S identification
Looking at mostly S's.
Some are de-badged on the trunk, so no "S" identifier.
Door rails have the "S", but they can be added simply.
Dual-exhausts, but they can be retrofitted to a 2.7.
White guages, but I've seen those on base models too.
So, aside from a few insignias, dual-exhausts and white guages,
is there anything else that will definatively indicate S,
that isn't easily modified?
Something like maybe the sixth digit on the VIN is "S" instead of "B".
Can't change that.
02-08-2017, 02:06 PM
The S model has an oil cooler in front of the car:
whereas the base model doesn't have that:
Also you can check if there is an real oil cooler behind the opening.
Regards, Markus
02-08-2017, 02:30 PM
still plays with cars...
You're right about the B, but it's the 5th position in the VIN, denoting the 3.2.
Markus has the centre front bumper cutout identified as well, but it's a 3rd radiator, not an oil cooler.
Six speed 2000 Boxster S
02-08-2017, 02:33 PM
6 speed transmission?
It requires different axles, uprights, clutch slave cylinder and cables.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
02-08-2017, 02:37 PM
can't forget the Big Brakes
2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
02-08-2017, 03:31 PM
White gauges with silver trim too
02-08-2017, 03:55 PM
Red Calipers
02-08-2017, 04:14 PM
Wow, oil-cooler ventilation on the front facia (used to be called the 'splashpan' I think). Major nose difference right there in front of my face and I never made the connection. Thanks SmallBlock.
VIN digit 5 is 'B' or 'S' for real? I just made that up as a hopeful.
That's very useful when checking Carfax/Autocheck online. Thanks Steve.
Six-speed on the S only - right.
I know about the brakes, but can you tell big brakes from the outside?
Are they distinctive? They're usually red on the S I think.
If you can tell visually that's useful. Thanks Dubaday.
I'll look for silver trim too - hadn't noticed that.
02-08-2017, 04:50 PM
Redline on tach...
02-08-2017, 05:09 PM
Lies, all lies. I have had S model bumpers on a base. Some people have swapped S front brake calipers onto a base. I have red (base) brakes on one of my '99s and In plan to paint the brakes on my S yellow. It's not hard to replace a gauge face or the whole cluster and trim pieces. There are some base models that have the six speed transmission swapped into them. Oil coolers from 3.2s have been swapped onto 2.5s and 2.7s.
Truth: Correct that an S model VIN will start with WP0CB... and a Base will start with WP0CA... .
S has heavier driveshafts and some suspension parts. Woody posted a great thread outlining some of the underlying hardware differences:
Pictorial differences between a base and S model Boxster
I bought an actual S model without realizing that it had a 1997 2.5L engine in it and I had already owned and worked on Boxsters.
Want to be sure of what you are getting? Have a reputable shop do a pre-purchase inspection (PPI).
02-08-2017, 05:50 PM
Its a center radiator, not an oil cooler
Markus, you are usually spot on, Having a bad day?
02-08-2017, 07:19 PM
Wow 78, that's exactly what I'm trying to avoid, something like 2.5 as S!
So your take is VIN is the only guarantee. Yes.
I had hoped VIN would differentiate something as major as an S powertrain.
The other examples are just common - if not foolproof - casual identifiers, and taken all together (emblems, guages, exhaust tips, brake calipers, ...) probably fairly reliable. Enough for a first pass where an inconsistency would lead you to a VIN check. If I don't see center air in the nose for instance, I'll check VIN to make sure.
02-08-2017, 07:29 PM
Originally Posted by Boxx
... So your take is VIN is the only guarantee. Yes.
The other examples are not lies, but common - if not foolproof - casual identifiers, and taken all together (emblems, guages, exhaust tips, brake calipers, ...) probably fairly reliable. Enough for a first pass where an inconsistency would lead you to a VIN check. If I don't see center air in the nose for instance, I'll check VIN to make sure.
Exactly.
(& no offense intended in calling all the other posters liars. My humor gets a bit dry at times.)
My experience is that lots of sellers, including used car dealers, have no idea what they are selling. Others know exactly what they are selling and how to make it look like what you want.
Again: If you are spending what to you is serious money, be sure to get a PPI.
02-08-2017, 08:21 PM
Trust the batwing.
02-08-2017, 10:39 PM
Actually that was funny. I just thought you were real adamant because you felt burnt on the 2.5 and didn't want any misinformation.
Out of curiosity, how long did it take before you realized the power probably wasn't a 3.2?
Did you test drive before and thought maybe it was just out of tune?
If it was me, it would probably be weeks or months.
02-09-2017, 02:24 AM
Little things to look for:
Big red brakes with drilled discs behind, the vented front bumper, 6 speed box which when going from 1st to 2nd when cold is always quite stiff, dual tip exhaust, the sill covers, white dials with 175mph speedo on the left dial, those are the normal giveaways but most of them can be retrofitted to base models.
Check the vin and drive a 3.2 back to back with a 2.7 and you will notice the main difference.
02-09-2017, 04:32 AM
Artist, 986S tinkerer
Then of course, a Durametric will give you the info you need concerning ecu vin and matching cluster vin and a wealth of other good stuff.
02-09-2017, 07:37 AM
Chrome trim ring around the windshield on the S, not on the base
02-09-2017, 07:54 AM
I am amazed that anyone would make a fake S. Am I missing something or wouldn't it cost more to do the mods on a base than to just buy an S?
02-09-2017, 08:30 AM
$77.00 from Suncoast Porsche. I just made my car an S.
