Little things to look for:
Big red brakes with drilled discs behind, the vented front bumper, 6 speed box which when going from 1st to 2nd when cold is always quite stiff, dual tip exhaust, the sill covers, white dials with 175mph speedo on the left dial, those are the normal giveaways but most of them can be retrofitted to base models.
Check the vin and drive a 3.2 back to back with a 2.7 and you will notice the main difference.
