01-27-2017, 02:13 PM
Is this engine trash ?? (Pic)
Hello!
Im pretty sure this engine is toast ,, just want to confirm
Any info is greatly appreciated
01-27-2017, 03:01 PM
I think you are looking at the wrong part; with that amount of piston to valve contact, you probably have bent valves.
01-27-2017, 03:31 PM
Bent valves and defective hydraulic lifters. Also valve guides. conrods etc. have to be examined.
01-27-2017, 04:41 PM
Cylinder wall is deeply scarred. New liner at minimum, so a complete tear down will be required. Along with the other noted problems.
01-27-2017, 05:32 PM
Awesome ,, Thanks everyone for the replies! and the help
yes the car had a broken spring on the #5 intake ,, I was able to pull all the pieces out of the cyl head so at least no nasty bits made it into the block .. this is a M96.24 engine out of an 03.
I was under the impression that these engines were not re-sleevable ? I will do a search on that process
Again thanks for the comments everyone !
01-27-2017, 05:57 PM
Valve + piston = teardown
Yes, the engines are re-sleeveable. Not sure why anyone would go to that expense, but it can be done.
Least expensive alternative is to buy a cheap used engine and swap it in.
01-28-2017, 10:32 AM
The cheapest junkyard engine I can find is 7k ,, just debating my options at this point
01-29-2017, 07:07 PM
I'd offer $3,000 even for the eBay engine and pay a shop $2K to swap them. You should be back on the road for $5K.
01-29-2017, 07:29 PM
Woody
01-29-2017, 07:31 PM
Originally Posted by eddy
Those motors won't work in his 03. There's less three chain motors to go around so they go for a higher price. $7000 is high though
Woody
01-29-2017, 08:03 PM
sorry bout that-- i missed that it was an 03.
01-30-2017, 10:27 AM
ok ,, I have the whole engine stripped down ,, looks like the damage was a broken spring that collapsed the Lifter and caused the valve to gouge the cylinder wall.
I may have found a low mileage clean used engine for a decent price but its out of an 06 I have searched to see if it was compatible with the DME in the car but can not find anything definitive ,, can anyone confirm that the 06 would work ??
01-30-2017, 05:26 PM
2003 - 2008 all have the same DME so a 2006 should be a straight swap.
From Pelican Parts: Boxster Tech Articles - Engine Swap
Boxster & Cayman 2003-08 (2.7L / 2.9L / 3.2 S)
The 2003 and later Boxster and Cayman cars can accept any 996/997 3.6 Carrera engine, and any Boxster or Cayman engine from 2003 and later. The best solution for more horsepower is to swap in
a 3.6 or 3.8 996 or 997 engine. You can swap in any replacement engine of the same displacement from 2003-08 without having to remap the DME. (I.E. a 2003 Boxster 2.7L with a blown motor can
accept a 2005 2.7L engine with no remapping needed).
01-30-2017, 05:31 PM
You can make it work but it takes someone who knows what they're doing to switch lots of parts from your dead engine onto the good motor. Be very careful. Something about locking the cams to remove the oil pumps or something like that. Hopefully JFP will chime in with the correct info. I don't know much about those later motors but I know it can be done
Woody
01-30-2017, 05:38 PM
Great info so far
Thanks again for the help!
02-01-2017, 03:34 AM
Beginner
Hello!
Confirmed.
2003 S manual
02-01-2017, 06:41 AM
it looks like i'm going with the M96.26 from the 06 ,, can anyone chime in on any modifications that are needed other the rerouting the brake booster vacum to the pump on the cyl head?
02-01-2017, 07:28 AM
Mine was a lot worst, thstone is right about swapping in a used engine which I did myself for $3,000 and never looked back
