Old 01-27-2017, 01:39 PM   #1
kjc2050's Avatar
Help diagnose oil leak
Sorry for the cellphone pics. Just noticed this today, on the driver's side, toward the rear of the engine. Any thoughts?
Old 01-27-2017, 01:50 PM   #2
check that pressure line (upstream where the wire from the sensor crosses) it, its black rubber with a pressure fitting at the end. Looks like oil might be crawling down the wire and collecting on the sensor.
brybart is offline   Reply With Quote
Old 01-27-2017, 04:45 PM   #3
911monty's Avatar
Total WAG but I'd guess spark plug tubes. Could also be from the power steering pump overflow.
Old 01-27-2017, 07:24 PM   #4
Pdwight's Avatar
Easy to tell if it is the plug tubes
Pull the coil pack and see if there is oil in there, or clean the block off and wait for the leak.....catch it early so you will know
