Old 01-25-2017, 12:15 PM   #1
Body panels
Am changing the radiator fluid in my 98 Boxster. Car does not have the plastic panel under the car that covers the radiator hoses. Does anyone have a full size drawing/template of one or have the full specs on one so that I make that piece? How important is it to cooling or aerodynamics? Or can I just buy one somewhere - for not too much money? Thanks.
ray_pilot is offline   Reply With Quote
Old 01-25-2017, 12:33 PM   #2
07 Carrera S Cab
Boxtaboy's Avatar
You can find them here:
1998 Porsche Boxster Base Convertible - Chassis Panels & Sheet Metal - Page 4
Old 01-25-2017, 05:59 PM   #3
Try itsnotanova (on here) for a used one.
sandia is offline   Reply With Quote
Old 01-25-2017, 07:38 PM   #4
Pdwight's Avatar
Surprisingly affordable
I would never attempt to make one for those prices
Old 01-25-2017, 09:44 PM   #5
On the slippery slope
JayG's Avatar
They are not really that expensive
UNDER COVER & SPLASH SHIELDS for 2004 Porsche Boxster
2004 996 Targa Tip
Instructor - San Diego region
Old 01-26-2017, 05:17 AM   #6
I'm thinking the last belly panel is not really that important as 75% are missing from the boxster that I get it and 20% are broken and barely holding on. I've only ever had 2 boxsters come in that had a rear belly pan that wasn't broke.
Woody
Old 01-26-2017, 09:54 AM   #7
BirdDog's Avatar
I ended up replacing all but the front belly pan on my 2001 S. They're really nothing more than splash shields.
They aren't all that expensive.
I'd recommend just ordering a new one - it would take forever for you to duplicate all the bends and stuff for that rearmost cover. Check the PET for part numbers, but you'll also need a couple of those 10mm plastic nuts (like those used for the rear wheelwell liners) that attach it to the body, four sheet metal bolts that attach it to brackets on the big aluminum reinforcement bars, and then there's also a 10mm nut that attaches it to a stud in the middle of the car.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 01-26-2017, 11:05 AM   #8
Thanks for the guidance. It's the rear splash cover (closest to the oil pan) that is missing. Now I just have to decide if I really want or need one. I'll do some shopping.
