Is my coolant tank empty?
https://uploads.tapatalk-cdn.com/201...4012c1e4b4.jpg
Hi, I just got my car back from the mechanic last week and an engine overhaul was apparently performed. I was just checking my coolant blue bottle cap for mayo and I notice the coolant tank to be empty. What can I top up with? Is distilled water OK? I got this car recently and have no experiences with cars before... The min/max level outside the tank doesn't help as the window is all hazed out.. The tank looks really empty. I wonder if the coolant is leaking? Sent from my SM-G930F using Tapatalk |
Yes, your coolant tank is empty, and yes you can use distilled water, it won't hurt anything unless you live in a really cold area. Ask the guy who worked on the car about what he did! |
You may have an air pocket in the cooling system - be very careful not to overheat the engine with this loss of coolant..... How does your oil level look - any indication of water in coolant (milk shake), indicating an internal coolant leak.
1) Try cleaning the inside of the tank using a rag dipped in vinegar - try a screwdriver if your fingers are short - just enough so you can see the level . 2)Top the coolant up with distilled water. 3) Under the black plastic cover in your photo, you will find an expansion valve with s chrome D shaped ring - lift the ring up into the vertical position (that's open) and drive your car for 3 - 4 days to expel any trapped air. Check the coolant level daily until it stabilises. 4) Return D ring to its close position. 5) If the level still goes down, you have a leak - return it to your mechanic pronto. |
The only other comment that might help a newbie is that even if the tank is hazy, you should be able to see fluid / non fluid line when looking at the tank when shining light from the rear trunk. If not, you definitely need to add distilled water asap & follow instructions provided here. Good luck!
engine overhaul
Pull the trunk carpet up under the tank and see if it's wet. These tanks will fail and leak into the trunk.
| All times are GMT -8. The time now is 10:07 AM. |
