Old 01-12-2017, 08:53 AM   #1
Tutorial on Fan Testing
Is there a tutorial out there that details the testing of the various fans?
Thanks!
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is offline   Reply With Quote
Old 01-12-2017, 09:16 AM   #2
cooling ,SAI ?
Old 01-12-2017, 09:59 AM   #3
If you disconnect the harness at the radiator fan. The prong in the corner is the ground and the other two are low or high speed fan. I use a battery charger to test fans and the resistor.
Woody
Old 01-12-2017, 10:23 AM   #4
Thanks!
The fans can be activated with the Durametric software.
Old 01-13-2017, 04:09 AM   #5
mikesz's Avatar
Pedro has a good DIY. As mentioned above you can use the Durametric if you have one. I removed the 4 relays above the fuse block and made myself a "jumper" with a piece of wire and 2 spade connectors on each end. Put one spade in the top center slot and bottom center slot where the relay plugs into. Your fans should run if not you have a problem. 2 of the relays are for low speed 2 for high speed. When I checked mine the right fan wasn't working at al and the left only on low speed. testing them is easy replacing is much more fun.
99 Porsche Boxster
