Old 01-07-2017, 07:47 PM   #21
Pdwight's Avatar
6 gallons
Of coolant ???
No wonder my car has never had an inkling of overheating.....I was once trapped in Nashville TN during August (Interstate crash) for over an hour in 100 deg + heat running my AC on high and never once did the needle budge
Old 01-08-2017, 06:02 PM   #22
Originally Posted by jeeper31 View Post
Lol. I don't mind spending the money. When I picked up the coolant fro lm the dealer the parts guy asked the service guy how much I would need. He said only 1 gal Of coolant and 1 gal Of water. He only sold me 1 gal Of coolant.
I remember going through a similar thought process when I did a coolant R/R at about 90K. I tried like heck to talk myself out of P car coolant. I finally bit the bullet and got the stuff from the dealer. My rational was this:
Buy autoparts coolant (Zerex extended life) for $20 x 3.
Buy P car coolant for $34 x 3.
At the end of the day, given the age of the car (and me!), I figured I'd most likely never have to do it again. So the extra $40 for the rest of my ownership sounded pretty cheap.
BTW, I R/R my WP at 128K miles. So much for my plan!
Old 01-25-2017, 08:20 PM   #23
jeeper31's Avatar
So does anything work smoothly?
Got the water pump and thermostat in. Hoses connected and belt on. Filled system up with distilled water. It only took about 3.5 gals. Ran it with heater on high and fan on high till radiator fans went on all the while checking coolant level. It seemed to stay the same or get higher. I also noticed that the bleeder plug, which was in the closed position, was actually raised to the open position. Turned car off. Cap was hard to open. When I did get it open a water started spewing out from under he cap. Didn't want to open it all the way. I know there should be pressure but this seemed excessive. What's up?
Thanks.
jeeper31 is offline   Reply With Quote
Old 01-25-2017, 09:14 PM   #24
JayG's Avatar
In order to fully clear out the system, you need to either disconnect the front rads at the bumper, or blow the coolant out using compressed air. Otherwise all your drain out is around 3-4 gallons
I did a full flush with distilled water and then refil with 50/50
If you can get a airlift to use, it will save you a lot of time and actually fill the system without air bubbles
Old 01-25-2017, 09:44 PM   #25
jeeper31's Avatar
So what's the deal with all the pressure?
Old 01-25-2017, 10:02 PM   #26
JayG's Avatar
There are a lot of hoses plus the rads that trap fluid
Old 01-25-2017, 10:11 PM   #27
jeeper31's Avatar
Would that cause enough pressure to open the bleeder valve?
Old 01-25-2017, 10:23 PM   #28
Pdwight's Avatar
Could be bad O Rings
allowing coolant to slip by while hot....I just went through this....easy fix if that is what it is
Old 01-25-2017, 10:30 PM   #29
jeeper31's Avatar
What's the fix?
Old 01-26-2017, 09:08 AM   #30
It always opens when the motor is at operating temp. Its designed that way.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-26-2017, 10:59 PM   #31
I am my own mechanic....
Timco's Avatar
Expanding fluids in a closed system. Lots of pressure. Air compresses. Water does not. You need some air trapped in the coolant res.
I raised the rear of my car to refill. Zero air. Your results may vary.
'08 VW Touareg T-3 wife's car
Old 01-27-2017, 03:39 AM   #32
Santa Barbara, CA
Does this explain the many threads about smelling coolant when there's no indication of any leakage?
jvfante is offline   Reply With Quote
