Old 01-01-2017, 08:28 AM   #1
Giller's Avatar
Rear Shelf Speaker Question
I installed speakers on the rear shelf this past year - but failed to remember that the shelf has to come out in order to get at the engine. With the speaker wire running front to back, it makes it very challenging to remove the shelf as I have to then pull the wire out to get enough slack....
Does anyone have a suggestion on what one can do to insert some sort of easy connect/disconnect spliter in the speaker wire itself?
