Old 12-25-2016, 09:55 AM   #1
jeeper31's Avatar
Leak and noise help
I have a clanging noise coming from the rear. I put the car up on ramps and looked underneath to find a bad leak. What fluid is it? Where is it coming from? it sesms the noise is internal. You can hear it in the video Is that tranny fluid? Thoughts/opinions. Thanks in advance
video here:
https://youtu.be/K_yo9DoiHtE
jeeper31 is offline   Reply With Quote
Old 12-25-2016, 11:07 AM   #2
AZ986S's Avatar
That looks like engine coolant. Can't say where it's coming from. You'll likely need to clean/dry it up, crawl under with a flashlight (with goggles) and pinpoint the source. Likely a hose or seal.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 12-25-2016, 11:20 AM   #3
jeeper31's Avatar
Thanks. Any chance this is the cause for the clanging?
Old 12-25-2016, 12:10 PM   #4
Most likely you are losing your water pump. Do not drive the car, it the pump fails completely, it could cost you your engine as well.
Old 12-25-2016, 03:15 PM   #5
Lew
So Blessed!
Lew's Avatar
Could be the sounds of the water pump's empeller that is broken and rattling around.
Lew is offline   Reply With Quote
Old 12-25-2016, 06:37 PM   #6
BirdDog's Avatar
Sounds like it's the water pump... either impeller blades striking the block from a failed bearing, or broken blades bouncing around in there...
1. FIRST, DO NOT run the engine again until you replace it.
2. While replacing the pump, check the aluminum block for impeller damage.
3. Make sure you can account for all the impeller blades. If any are missing, they could be lodged in the coolant passages in the heads, restricting flow, and causing a hot spot. That could result in a cracked head.
4. Replace the pump with an OEM pump. Pierburg = factory Porsche (feel free to pay more for one in a Porsche box if you really want to spend money).
5. Do not use a pump that has metal impeller blades.
Old 12-26-2016, 07:47 AM   #7
jeeper31's Avatar
Part is $350 from local Porsche Dealer. Pierburg is $244. From Rockauto the Hella, which says Pierburg in the description is much cheaper. I think $190. Wondering if that's really a Pierburg.
I am assuming I should do the thermostat as well. Any advice there?
Old 12-26-2016, 08:01 AM   #8
Lew
So Blessed!
Lew's Avatar
Hella water pumps are German made if interested....They are excellent pumps. Ain't cheap!
Old 12-26-2016, 08:07 AM   #9
jeeper31's Avatar
Yeah just looked again. It's only $190. But says Pierburg OE Quality. So it's not a Pierburg.
Old 01-17-2017, 10:37 AM   #10
jeeper31's Avatar
Hit the water pump and found a little part of one impeller missing. Is there something I need to do now?
Old 01-17-2017, 03:40 PM   #11
Steve Tinker's Avatar
If you are (very) lucky, the broken bit could be lodged in the thermostat housing. If its not there, it could be anywhere in the cooling system - just hope that its not lodged in one of the cylinder head waterways......
You can try back flushing, but people have had mixed results - try using the search function for broken impellers.
2001 MV Agusta F4.
