Old 12-22-2016, 01:26 PM   #1
Parasitic Battery Drain
Has anyone ever had a problem with a parasitic battery drain ? If I go more than 10 days without driving my car I have to charge the battery. Can it be something simple ? Easy to check ?
gmboxster is offline   Reply With Quote
Old 12-22-2016, 01:58 PM   #2
New to you car or new problem with old to you car?
Any aftermarket electrical items ever been installed?
Yes, a problem that has been reported many times.
Ignition switch, aftermarket items are the usual. Start by checking the drain fuse by fuse to see if that yields and clues. How to and some values to expect here several pages down..
Old 12-22-2016, 02:36 PM   #3
I have a 1998 and this problem is fairly recent. It has never had any electrical options installed. But I'll check the fuses. Thank you.
Old 12-22-2016, 06:01 PM   #4
Very easy to check. Here is how I did it: Spec Boxster Build
My Spec Boxster race car (which is mostly stripped) had a residual current of 2mA. If the battery is draining in 10days, I would expect the drain to be several tenths of a amp.
Or it could be a bad battery.
Old 12-22-2016, 07:25 PM   #5
Lew
So Blessed!
Lew's Avatar
This is how I check for a Battery Drain.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
