Old 12-05-2016, 11:53 AM   #1
Oil Drain Plug - "Updated" Magnetic plug
Hi everyone, I was wondering if anyone has tried this new, updated version of the magnetic drain plug that is now offered on pelicanparts?
It is called: Billet Aluminum Hard Anodized Magnetic Drain Plug, (requires one 900-123-106-30 sealing ring)
Link: 2003 Porsche Boxster Base Convertible - Filters & Belts - Page 3
My current OEM plug is starting to get stripped so I want a new one and am curious about this magnetic plug. I remember when I was considering ordering one a year or two ago there was a lot of comments regarding how the magnetic plug was soft and would either strip or break. I would appreciate any comments regarding if this new, updated plug is stronger or has any other issues with it. Thanks!
ttmedical is offline   Reply With Quote
Old 12-05-2016, 12:59 PM   #2
morgal48's Avatar
Bought and installed one a couple weeks ago. To replace the one that I broke. Learned objectively to ensure that the 8mm allen driver is seated. I did not and sheared the head off. Also forgot the 18 vs. 37 ft-lb thing. Only problem with the old one was operator error. The remaining portion of the plug does not seal well.
2000 Boxster S
2010 Volvo XC60
2011 GMC Denali HD 6.6L (sold)
2008 Cayenne S (sold)
1989 Targa (sold)
morgal48 is offline   Reply With Quote
Old 12-30-2016, 09:03 PM   #3
gomarlins3's Avatar
I have had one and used it for over a year and was going to do my third oil change with it and stripped it out this morning. Now I am struggling with how to solve my problem of getting it out of the pan.
gomarlins3 is offline   Reply With Quote
Old 12-31-2016, 04:18 AM   #4
Get an allen key that is just a hair larger and use your hammer to insert the larger allen key. If key is just to big you may have to use a grinding wheel to make the appropriate size. If that does not work Craftsman make a lot of tools for the removal of stripped nots and bolts!
jerry and sons is offline   Reply With Quote
Old 12-31-2016, 04:26 AM   #5
A very good & important point.
Old 12-31-2016, 06:17 AM   #6
Project Addicted
jcslocum's Avatar
Use a big torx drive to hammer in.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 01-21-2017, 07:34 PM   #7
I wish I had saw this post this morning. Shredded the plug in the hole, I'm just hoping the threads in the case are ok.
gpope is online now   Reply With Quote
Old 01-22-2017, 09:39 AM   #8
Good tip, thanks
That will work ! - one time. Great way to extract one that you intend to replace.Eventually it will chew up the hex recess to the point where more radical methods may be required ?
Old 01-22-2017, 02:47 PM   #9
gomarlins3's Avatar
That is what I ultimately had to do. Replaced the magnetic oil drain plug with the OEM one.
Old 01-22-2017, 02:58 PM   #10
You can always put rare earth magnets on the filter instead .
Old 01-22-2017, 05:34 PM   #11
Artist, 986S tinkerer
NewArt's Avatar
I ended up by cutting a slot in the plug with a dremel or something. I then used a jack holding an air hammer chisel bit (just the bit, not the hammer) in place and turned the bit with vice grips. Lowered the jack gradually once it broke free. I then replaced the plug with the old oem one! Don't wanna do that again.
Old 01-22-2017, 09:27 PM   #12
After reading these. Think I will go back to the OEM plug and magnets on the filter housing
Duezzer is offline   Reply With Quote
