11-24-2016, 01:06 PM
Distorted Screen
Hi.
Can anyone suggest how to get my climate control screen to clear up?
I caused this a few weeks ago when I was whipping down the interior. I did not squirt any cleaner in there, but the rag did have some on it. I also don't think I pressed too hard, but apparently I must have. Since the initial damage, the screen has cleared quite a bit, but this image here is pretty much how it's looked for over a week. So I'd say it's not getting much better now.
Any ideas on how I might get this to clear up?
Thanks!!
11-25-2016, 04:13 PM
still plays with cars...
Looks like you have a damaged climate control LCD.
One of these https://modulemaster.com/rebuilds/shop/comfort/lcd-repair-kits/porsche-lcd-kit/ will fix you right up.
Six speed 2000 Boxster S
11-25-2016, 09:08 PM
How on earth does that work? By the looks of the pictures it looks like you have to disassemble the entire climate controller, yet the write up indicates otherwise.
Thanks for the reply.
11-25-2016, 09:33 PM
Yes, you have to remove and disassemble the climate control unit to replace the screen. It's easy.
11-26-2016, 09:39 AM
07 Carrera S Cab
I just bought a working used one (entire unit) on fleabay for $75 shipped as a spare if mine ever craps out.
11-26-2016, 12:57 PM
The kit is very easy to use as others have said.
2002 Porsche Boxster Carrara White - 103,000 miles
05-24-2017, 11:16 PM
I just repaired using an new LCD kit for $60. Piece of cake, took about 20 minutes and works perfectly.
2020 Taycan Turbo S - DD Rain
2015 Huracan - DD Sun
2002 Boxster - Play Car
2000 C2 Aero - Track Car
1965 Dodge Coronet 440 - Nostalgia
05-25-2017, 09:10 AM
The LCD repair kits are easy to install as long as you take your time and are detailed.
I did mine last Summer--well worth the effort.
'02 Boxster S
'16 GTI PP
'17 Bolt (with a B)
05-25-2017, 09:46 AM
If you buy a used climate control module there's no guarantee it won't do the same thing to you down the road. Best to get the repair kit. I got it and took mine apart with instructions provided and it was no big deal.
05-26-2017, 06:25 AM
Originally Posted by JayG
This is the one I used and it was great.
An exact replacement for the original.
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
05-26-2017, 09:16 PM
will even work in your car, not all the same. I did this and the control unit was not compatable with my car. I would up exchanging the LCD screen only using the one I purchased as a donar
