Old 11-20-2016, 06:04 AM   #1
Engine/electricals shuts down when using A/C
It start with flickering of cluster display, a/c display. It shuts off when auxi fans kicks in. I already installed a brand new steering lock assembly with ignition switch as well as new battery. Restarting the engine is not a problem.theres always ample supply of electricity.
Anyone encounter this similar problem?
RedRimowa is offline   Reply With Quote
Old 11-20-2016, 06:55 AM   #2
CrisZenithBlue's Avatar
Check if your alternator is charging properly. You can go to autozone and they check your battery and alternator for free. If it's the alternator get a refurbished one for 150$ with lifetime warranty, replacement is fairly easy.
CrisZenithBlue is offline   Reply With Quote
Old 11-20-2016, 07:07 AM   #3
This would be easy to diagnose for a vehicle electrical specialist.All he needs to do is monitor Alternator voltage and current with a/c on/off.
Old 11-20-2016, 01:00 PM   #4
Steve Tinker's Avatar
He's in the Philippines - I doubt that Autozone has an outlet anywhere close by....
2001 MV Agusta F4.
Old 11-22-2016, 06:10 AM   #5
Hi guys!
Thanks for the repliesz. Yes, I am from the Ph and porsches are not that plenty. l'll look for a reputable car electrician to do the job as what you have pointed out. I'll keep you update as soon as possible.
Old 11-22-2016, 02:17 PM   #6
Pdwight's Avatar
Everyone
Buy a voltmeter and learn the basics.....it will save you so much time......a $25 unit will do plenty
https://www.youtube.com/watch?v=bF3OyQ3HwfU
