Old 11-16-2016, 01:05 PM   #1
Ebrake issue
I pulled up a bit hard on the ebrake handle tonight and for some reason couldn't get it to release. When I pulled off the bit off molding to see what was up, |I noticed that a pin/sleeve had slid out about a centimeter causing the whole unit to shift so that I cant release it. No it's not that I need to pull harder and then press to get it to release. The button actually slides in and stays in because it's out of position.
Is there a way to disconnect or loosen it from within the car so I don't have to pull the wheels? It's raining very hard at the moment.
Thanks in advance for your help.
I tried to pull the sleeve/race/pin..whatever it's called out the rest of the way but only managed to chew it up. It's pretty soft.
Eastcoastmod is offline   Reply With Quote
