Old 10-22-2016, 04:14 PM   #1
Unhappy Dead battery? Won't start. Help
I have a 2002 Boxster I use as a daily driver. I recently had surgery and was grounded from driving (anything) by my doctor. Well, I'm ok to drive again, but the car won't start or turn over.
The Boxster was idle over two weeks, I've read about immobilizer issues. My added problem is the electronics in the key have been lost for months. I've just been getting in abs starting the car within 10 seconds (and gotten quite good at it).
At first, thinking this was a dead battery, I pulled off the fuse box cover and attempted the steps to open the hood. When jumper wires are attached, and the key turned, the alarm sounds and I still can't open the hood.
So it's the key - right? Or not.
I need to start the car to move it. Can anyone help?
Randy
2002 Boxster Seal Gray Metallic: Desnorkled, Changed ashtray to non-smoker's bin, Removed stickers from sunvisors, Added rear speakers, LED Shifter, Porsche logo on trunk lid, New top with heated glass window, Aspheric Driver's Side Mirror Upgrade, More to come...
randy7601 is offline   Reply With Quote
Old 10-22-2016, 05:53 PM   #2
2003 Base 5-speed
grc0456's Avatar
There should be a manual release cable. Look up in the front of the passenger wheel well for a piano wire with a loop on the end. Some people relocate them to the front tow hook for easier access.
Old 10-23-2016, 06:18 AM   #3
Project Addicted
jcslocum's Avatar
The wire to pull the release is on the pass side, hidden up behind the headlight
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 10-23-2016, 07:53 AM   #4
07 Carrera S Cab
Boxtaboy's Avatar
If your car is near enough to an electrical socket, you can use a trickle charger that plugs into your cigarette lighter socket to get enough power to open the frunk.
Old 10-23-2016, 12:00 PM   #5
Maintainer won't work if fully discharged battery. Don't try to start using the charge thru the lighter charger as wires will fry. .
Just get the frunk open via the charger thru the lighter.. Then charge the battery.
If that fails, use the techniques here. And relocate the emergency cord to behind the bumper access panel so it is easier next time.
Old 10-23-2016, 06:46 PM   #6
SUCCESS! We used Third Method (Eric adds) to open the frunk. From there it was just replacing the dead battery with a new one.
Thanks eveyone!
Randy
