Old 09-25-2016, 05:44 PM   #1
deliriousga's Avatar
Fuel injector electrical connections (misfires in 1, 2 & 3)
I've had a problem with cylinders 1, 2 & 3 misfiring but it's still going on after some fixes. I already replaced the secondary air pump (it sounded horrible so it was time) and replaced all three coils on that side and the plugs. I plan to replace the coils on the other side since I'm at 200k miles, but could only find 3 to buy at the time. I'm still getting misfires on that side so I'm guessing it might be the electrical connection to the fuel injectors. I don't think all 3 injectors would die at once. Anyone know where the fuel injector electrical connections are and if there is a connector for each side and if theyre easy to get to? I had a mechanic fix some vacuum leaks and that's when this started happening so I really think something is just loose.
Thanks for the help!
Old 09-25-2016, 07:58 PM   #2
Do you have a MIL code & if so, what is it ?
If you have no code, it could be more vacuum leaks.
Old 09-25-2016, 10:55 PM   #3
CEL P0306
I had a connector related misfire, but only at one cylinder. Just needed to be snapped more solidly in place. They connect to each fuel injector - just follow the wire. Pretty easy to spot.
aczyzewski is offline   Reply With Quote
Old 09-26-2016, 12:05 AM   #4
madmodz's Avatar
If you let a mechanic work on it, I would check that your coils are fully connected. The rubber covers secure the connector good and it's easy not to fully push the connector to lock.
I would do the same thing with the fuel injector plugs. If it doesn't fix your problems it's easy to mix up vacuum hoses. That was my issue.
madmodz is offline   Reply With Quote
Old 09-26-2016, 09:01 AM   #5
300,301 & 302 are the codes. Misfires in all three right-hand cylinders.
1966 Wife White/Brown Top
Old 09-26-2016, 09:05 AM   #6
I did the coils/plugs myself after the problem started so I know those are tight and they're the new, updated type with the longer screws. Where can I find the fuel injector plugs? I'm thinking they unclipped the plugs when they were fixing vacuum leaks and they weren't secured properly when they finished since it ran fine for a couple of days and then all of this suddenly started happening.
Old 09-26-2016, 10:19 AM   #7
Check common connections first, like your engine ground strap. A bad connection could lead to an excessive voltage drop.
Sent from my SM-G930W8 using Tapatalk
newBgeek is offline   Reply With Quote
Old 09-26-2016, 03:28 PM   #8
Steve Tinker's Avatar
A high resistance ground strap would cause all sorts of other problems too - including the other 3 (good) cylinders to misfire.
2001 MV Agusta F4.
Old 09-26-2016, 05:17 PM   #9
The Radium King's Avatar
since entire bank is in fault then misfires could also be due to timing on that bank, or faulty o2 sensor setting bad trim. with a durametric you could record actual values for fra and cam position.
