Old 09-25-2016, 08:09 AM   #1
Jay B.'s Avatar
Brake wear light
Yesterday my brake wear light came on while I was driving and when I shut it off and restarted the car the light didn't come back on. I know my brake pads are not worn because I just replaced them about a month ago. I did a quick inspection and all sensors seem to be seated correctly in the pads so I'm guessing the sensors are failing. Is this a common issue with these cars? I see online that these sensors are pretty cheap so should I just replace all four sensors and be done with it or do I have a bigger problem with the brake system?
2000 Boxster S
Jay B. is offline   Reply With Quote
Old 09-25-2016, 08:45 AM   #2
The light will also come on if your brake fluid level is low or sloshing about.
