Old 09-24-2016, 01:43 PM   #1
Question on convertible top strap for service position
I thought it would be a good idea to check my front and rear drains today. Since my car is garaged they were perfectly clear. But in the back on the driver's side, I saw this strap just lying in the well under the clamshell. A little research and I found it is to hold up the rear window when the top is in the service position. The end of the strap has a Velcro section. Attached to that piece of Velcro was the corresponding piece that had been glued somewhere, but that piece has come unglued. This is a 2003 Boxster with glass rear window. Does anyone know where this piece of Velcro should be re-glued? Thanks in advance.
Old 09-24-2016, 02:27 PM   #2
Sure, if you cup your hand, fingers towards the back of the seat and run it up under the back of the top about about half way to the rear window you should feel where it was attached. Go slow and watch out for any sharp edges.
That should do it.
fanguy is offline   Reply With Quote
Old 09-24-2016, 04:35 PM   #3
Thanks, I didn't go that far, will look again tomorrow!
Old 09-24-2016, 05:32 PM   #4
stelan's Avatar
Interesting, mine does not have these, I see them being useful
stelan is offline   Reply With Quote
Old 09-24-2016, 08:45 PM   #5
KevinH1990's Avatar
I think they are only on the 2003/2004 tops which have OEM the glass window. My 2000 didn't have one, but the 2004 top and frame I swapped in did.
Old 09-25-2016, 06:31 AM   #6
I think a bungee cord with the right hooks that don't scratch or tear plastic, fabric and weatherstripping can do the same thing. When I first saw the strap I thought it came out from between the top and the headliner. I learned what is was at Pedro's website under accessing the engine.
