Old 09-21-2016, 01:56 PM   #1
Shave master
Convertible top repair bottom became untucked.
I tried searching to see what others have done to fix this, but had a hard time coming up with search terms. The top became untucked from from, What is the best was to get this back in place. Do I use an adhesive?
sleepingboxster is offline   Reply With Quote
Old 09-21-2016, 04:08 PM   #2
Rennzenn
j.fro's Avatar
Double sided 3m tape. Separate all of the bottom, clean it well with acetone, and redo the entire bottom edge.
Rennzenn
Jfro@rennzenn.com
Old 09-21-2016, 06:28 PM   #3
Porsche "Purist"
Paul's Avatar
Skip ahead to 7 minutes in....
https://www.youtube.com/watch?v=40BXEt07fGU
1987 924S. 2002 996TT. PST-2
Old 09-21-2016, 08:29 PM   #4
I used 3M spray adhesive....spray onto paper plate and apply with foam brush. Two years and still holding.
Old 09-22-2016, 02:52 PM   #5
Shave master
Thanks guys. Advise was helpful, I just called a top shop and they want $65. How long do you think this will take if I do it myself?
Old 09-22-2016, 02:58 PM   #6
Using 3m it took me about 5 minutes to apply and about 10 min to set up enough to let it finish on its own. I opened the top enough to take the tension off the area.
