Old 09-11-2016, 08:31 AM   #1
Jay B.'s Avatar
Radiator cleaning tip
I went to Harbor Freight Tools yesterday and bought this air gun extension rod for $4.00 and it worked great at blowing the road debris out of the radiator fins. This extension reaches all the way back through the radiator grills. I will definitely be cleaning these radiators on a regular basis now since these radiators inlets are basically street vacuum cleaners.
2000 Boxster S
Jay B. is offline   Reply With Quote
Old 09-11-2016, 08:54 AM   #2
Hopefully it doesn't harm the radiators. Did this with a power washer once and never again, bacause i had to buy new radiators.
I my opinion best way is to remove the front fender and inner parts and clean the radiators with a vacuum cleaner. Also if you have air condition you have to remove the air condition radiators to get the dirt out between air condition radiators and water cooler radiators.
Regards, Markus
Old 09-11-2016, 12:06 PM   #3
Mig
I found a lot of debris in between the condensers and radiators this summer after I pulled everything apart.
I fabricated some mesh grills and painted them black along sign the grills. A nice refresh to the front of the car.
I tried uploading a photo from my iPad, but it wouldn't work. I'll have to try again from a proper computer.
Mig is offline   Reply With Quote
Old 09-11-2016, 12:50 PM   #4
2003 Base 5-speed
grc0456's Avatar
Pull the bumper off. That power washer probably won't get debris between the AC condensers and rads.
Then fasten some mesh for your grills to keep most of the future debris out.
