Old 10-05-2016, 09:03 AM   #21
Also be aware that just about everyone that change AOS's for a living have reported questionable units band new, right out of the box. We check the vacuum level on every one we install; if the vacuum ain't right, it comes back out again.
And whatever you do, do not buy aftermarket units, we have had zero luck with them and now only use the factory part.
Old 10-05-2016, 01:01 PM   #22
911monty's Avatar
Originally Posted by Racer Boy View Post
The chances of a pump actually failing have got to be pretty tiny.
Removing the pump wasn't that bad. It looks like it would be easier than replacing the AOS.
But......they can fail as shown in thread attached. They're not likely to wear out though.
Blown AOS & Oil leaks - Look what I found........
