Old 07-10-2017, 05:56 AM   #1
Artist, 986S tinkerer
NewArt's Avatar
Front control arm bolt tightening?
Bentley says the inner bolt needs to be torqued to 120Nm under load. I can see no way to put a socket and torque wrench on this nut! I used a box end and cheater tube to tighten it as much as possible with limited space since the car was up on ramps. Maybe I'm fretting for nothing. Any input?
Old 07-10-2017, 10:34 AM   #2
Just got done with this same project. You are correct about not being able to get a torque wrench in there!
Inner bolt and nut need to be tightened with the car on the ground. If you can't do it that way, at least get a jack under the hub and lift the hub up to put a load on the assembly.
Like you, I ended up torquing the inner bolt and nut as tight as I possibly could.
Old 07-10-2017, 10:47 AM   #3
The project requires the use of the correct sized crows foot extension on the torque wrench, being sure to use proper adjustment to the torque value target.
Old 07-10-2017, 11:08 AM   #4
NewArt's Avatar
Thanks, I thought that might be the case!
Old 07-23-2023, 09:27 AM   #5
Reviving a super old thread. Getting ready to install PSS9s and was wondering the same thing. The manual makes it sound like no big deal…just torque it on the ground….with 3 inches of clearance 😂
Guess I need to make a another harbor freight run for crows feet.
Danimal is online now   Reply With Quote
Old 07-24-2023, 03:38 AM   #6
1998 Boxster Silver/Red
Does anybody read the posts? Dude said, in 2017, he had the car on ramps when torquing.
Ramps. Ground. Ramps. Ground.
Anyone see the connection here?
lol
1998 Porsche Boxster
