Old 08-21-2016, 08:52 AM   #1
oc-boxster's Avatar
Cleaning top.
I have the 303 cleaner/sealer kit for my convertible top, and noticed the last one I used the cleaner it got ALOT of dirt out of the top since I have to park the car outside. I've decided I'd like to use the cleaner every couple months or so. My question is do I have to reapply the sealer every time I clean the top? Does the cleaner remove the water repelling sealer?
oc-boxster is offline   Reply With Quote
Old 08-21-2016, 09:37 AM   #2
There Is No Substitute.
rick3000's Avatar
I could not find any information that explicitly says if 303 cleaner will strip the waterproofing. I would recommend emailing 303 directly about it, but my guess would be, if it isn't stripping the waterproofing it is at least diminishing it. Since you are parking outside I would probably re-waterproof the top after cleaning, just to maintain the UV protection provided by the waterproofing.
Old 08-21-2016, 09:47 AM   #3
2003 Base 5-speed
grc0456's Avatar
I agree with Rick. I'd re-seal it every time I clean it. Usually 2x per year is all that is needed, unless you're parking under a tree each day.
Old 08-21-2016, 09:56 AM   #4
I'm the 2nd owner to use 303 and my top is the original 16 year old top - it still looks great! Whatever it does...works. I'm happy with that!
Old 08-21-2016, 09:59 AM   #5
oc-boxster's Avatar
Thanks guys-303 is great stuff. The water repelling action is impressive. I forgot it also provides UV protection, so it will apply a thin coat every time I clean it.
Old 08-21-2016, 06:13 PM   #6
Pdwight's Avatar
Nanodyze
You guys should try this stuff.....last 10 times longer than Ragtop
Old 08-22-2016, 05:41 PM   #7
I've been using the chemical guys cleaner repellant kit, I believe its worked out well. however, I have nothing to compare it too.
glenf is offline   Reply With Quote
Old 08-24-2016, 03:46 PM   #8
Porsche "Purist"
Paul's Avatar
The top is 2 layers, a permeable cloth layer and a rubber layer....
1987 924S. 2002 996TT. PST-2
Old 10-12-2016, 05:15 PM   #9
where can I buy Nanodyze? Aparently the Ragg topp people are no longer taking orders. I ordered Set. 2 , got a nice thank you acknowledgement but no product. Need to do this NOW. Nanodyze or Nanolex sounds better. Where to order?
rockstar68 is offline   Reply With Quote
Old 10-12-2016, 08:18 PM   #10
Pdwight's Avatar
Here you go
https://www.amazon.com/NANODYZE-Fabric-Protector-Preventor-Waterproof/dp/B00MKZ7Q0U
