Old 08-15-2016, 10:34 AM   #1
Spoiler only raising 1"
As the title suggest, the spoiler works fine going up/down (no error light) - but is only going up 1". I'm pretty sure via pictures it looks like it normally extends 3-4".
I haven't replaced the fuses yet, but IMO a broken or faulty fuse would cause it to work/not work... not limit it's travel. Any suggestions?
~Alura
aluratek is offline   Reply With Quote
Old 08-15-2016, 11:13 AM   #2
I had the same problem.
It ended up being a "bad" motor. I replaced the motor and mine is working fine now.
The motor would raise the spoiler up 1", bind up and stop.
No problems lowering the spoiler at all.
I am not sure if there is a limit switch (I doubt) or it just runs till a certain amount of resistance is met and stops.
You could also try cleaning and lubing the spoiler cylinders (or whatever they are called) that the spoiler rides on and see if that helps.
emore93 is offline   Reply With Quote
Old 08-15-2016, 12:29 PM   #3
jb92563's Avatar
Ahhh, its only going up an inch because your not going fast enough.
