Old 08-10-2016, 11:28 AM   #1
Nitpicky Item Ignition Trim
Howdy,
I am acquiring parts and knowledge for a long list of preventative maintenance I will be performing in the coming months including a new clutch, water pump, engine mount, etc. among many other items. I actually look forward to doing this type of work. My better half understands my need to always be working on projects and the box seems to fall right into that.
My question in this post is about the ignition trim surround. The one on my car seems loose and my guess is this isn't a natural state for the part. Everything else in the car is so tight and properly fit together.
I haven't attempted removal yet. I just wonder if there is a way to tighten it up.
Thanks for any help.
Dave
2001S
dsallean is offline   Reply With Quote
Old 08-10-2016, 01:26 PM   #2
Project Addicted
jcslocum's Avatar
I recall it's a rubber grommet?? A new one might have a less rubbery feel???
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 08-10-2016, 05:07 PM   #3
Auf los!'s Avatar
Yeah, it's a synthetic rubber piece, tug on it, and it will pop right out. I think it's a little odd that it is loose on your car. A new one is $60 or so, and might fit better. But a couple of dabs of silicone behind your loose one will likely make it stay put.
2001 Boxster S 6-speed, 2013 Boxster S PDK
Auf los! is offline   Reply With Quote
Old 08-10-2016, 08:44 PM   #4
Wow. Think I paid less than half of that from Suncoast a few years ago...
Old 08-10-2016, 10:10 PM   #5
From my recent interior trim refinishing project, IIRC, the ignition trim is EPDM rubber. To tighten it up if it seems loose or has some unsightly gap, I'd suggest pulling it away and reinserting it more fully. You could also try "re-clocking" it (rotating it at a slightly different angle).
2001 Boxster
Old 08-11-2016, 06:43 AM   #6
Thanks for the responses. It sounds like it might be a simple task to remove it. If there is wear or anything broken I will just get a new one from Suncoast. Currently running $59.70.
Old 08-11-2016, 10:42 AM   #7
might want to check with reputable ebay used part seller like 'qualityporscheparts'. or itsnotanova on this board.
Old 08-11-2016, 01:34 PM   #8
Thanks that is a good idea. I have bought from Woody before and he is great.
