Old 08-04-2016, 03:25 PM   #1
boxster s windows and roof stopped working fuses seem fine
Hi All
I have a 2001 boxster s
both windows and the roof have stopped working
nothing from any switches or door handle sensors
also the roof release does not drop windows so the roof won work either
ive checked fuses and they seem good
does anyone have any sugestions
I'm wondering if it could be a relay but cant find which one
thanks in advance for any advice
Dave
hdavetaxi is offline   Reply With Quote
Old 08-04-2016, 04:20 PM   #2
Check Fuse Row C #3 , D3
Do it correctly - remove the fuse and physically inspect it for the correct Amperage and measure for continuity.
Did the carpet get wet? If in doubt feel under the seats for wetness.
http://www.renntech.org/forums/topic/38126-boxster-fuse-list/?_fromLogin=1
Old 08-05-2016, 08:01 AM   #3
hi
I will check floor for water ingress
don't think this will be it though as it happened after a week of really hot weather
do you know the location of the window relay
there is quite a few above fues box. of are windows and roof done via same relay
thanks
Dave
Old 08-05-2016, 03:30 PM   #4
Here is a link to a photo and description of the location of the relays.Just feel the largest relay while operating any of the switches you mentioned.If you feel the click, the relay and the switch and that fuse are O.K.
http://www.pelicanparts.com/techarticles/Boxster_Tech/22-FUEL-Fuel_Pump/22-FUEL-Fuel_Pump.htm
https://www.google.com/search?q=relays+Boxster+Pelican&tbm=isch&imgil=fxqWWLRi6BS0NM%253A%253BQrN6cHeGZFoqHM%253Bh ttp%25253A%25252F%25252Fwww.pelicanparts.com%25252 Ftecharticles%25252FBoxster_Tech%25252F22-FUEL-Fuel_Pump%25252F22-FUEL-Fuel_Pump.htm&source=iu&pf=m&fir=fxqWWLRi6BS0NM%253A%252CQrN6cHeGZFoqHM%252C_&usg=__GPd8xuhvALMA32ktu7p7fR64LoY%3D&biw=1536&bih=725&ved=0ahUKEwjnzcvTuavOAhUJ9IMKHd4EDLYQyjcIaA&ei=HySlV6fCI4nojwTeibCwCw#imgrc=fxqWWLRi6BS0NM%3A
But we're wasting time and bandwidth unless you have done a proper check of the appropriate fuses and wet carpet.Lots of vulnerable electrics under the seat and at the lowest part of the floor so blocked drains from the top will cause corrosion down there and endless electrical problems until you remedy that.
For more info ,look in the Bentley Manual. If you don't have one ,you'll be lost working on the Boxster.A great investment Your Owners manual shows relay locations(2)
https://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=porsche+boxster+Bentley+manual
Also search the Boxster Forums. Common problem - see RennTech for a whole section devoted to your issue.
http://www.renntech.org/forums/topic/24146-top-is-not-moving/#comment-126193
Just search in Renntech986 section for for "Relays top windows" lots there and here on the 986 Forum.
Old 08-06-2016, 06:53 AM   #5
Xpit77's Avatar
Check the switch for the roof latch. Sometimes the spring gets tired and doesnt contact. Try putting some tape or something on the hook to give it a bit of extra length. It worked on mine. I used a piece of those felt pads you put on the feet of chairs so they dont scratch the floors.Sticky back too.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 08-06-2016, 08:04 AM   #6
Thanks for this guys
UPDATE
floor is bone dry
I found that roof is actually working fine. just the windows don't drop
both windows stopped at exactly the same time.
so the only fault is that both windows do not operate from door sensor
window switches or triggered from the roof operation
thanks again
Dave
