Old 07-04-2016, 12:23 PM   #1
Safe to Drive with Idler Pulley Going Bad?
I noticed a "wobble" sound the other night coming from the engine bay. With the help of the search function of this forum I removed the front belt and thankfully the engine sounded fine without the belt. With the belt back on I was able to narrow down the location of the noise to either the upper idler pull or the belt tensioner. Both felt ok and spin freely enough by hand. The noise is only present when the car is at idle.
These appear fairly easy to change and I plan to do it myself. But I already have scheduled an appointment at a local indy for inspection and some brake work tomorrow. Any risk driving the car back and forth for the inspection? It would be about a 30-40 mile round trip. I'd rather not pay the premium to have the shop replace them.
JavPit is offline   Reply With Quote
Old 07-04-2016, 12:28 PM   #2
If it fails, you are stuck where ever it happens.
Old 07-04-2016, 01:21 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
Good luck and join AAA.
Old 07-04-2016, 05:37 PM   #4
1999 base
Meir's Avatar
Let me put this here.
Failed idler pulley and a fire - Rennlist Discussion Forums
Old 07-04-2016, 06:34 PM   #5
Pdwight's Avatar
A bearing tested under no load is not real test....how many miles on them ?
Old 07-05-2016, 06:40 AM   #6
Assuming they are original there are 76K miles on them. I drove it to the shop this morning with no issues.
