Old 07-03-2016, 06:41 PM   #1
husker boxster's Avatar
987 Boxster convertible top sides not tucked in
Disclaimer 1: Not sure if 986s have this issue, but it's prevalent with 987s.
Disclaimer 2: I did not come up with this idea. Rrunkle on Planet 9 did but I've added some detail and updates to it. Since I did not find a thread on this topic on 986forum, thought I'd pass it along to the membership. Plus I've swiped a cpl pics that I didn't take but need to assist with this thread.
The Problem: In Porsche's infinite wisdom, they use strings and elastic bands to keep their convertible tops in the proper position. Not good from a longevity stand point as both stretch over time and cause issues. When the elastic band stretches, it allows the canvas to go over the outside of the top bow, putting a lot of strain on the stitching holding the beading edge of the canvas roof. And once the canvas goes over the outside of the bow, the elastic band is stretched further and it will always go on the outside.
Make shift solutions: Stop the process of putting the top up just past service mode and get out and guide the top over both bows. Or you and the significant other reach back while the top is going up and guide the canvas inside the bow. Or I've heard you can push the top of the back window up and out which tucks the sides in enough to go inside of the bows. This doesn't work well if you have a windstop.
Solution 1: The elastic band has slots in it which allow you to tighten up the band. It requires a torx 15 socket. The first step is to release 2 Velcro straps that keep the headliner on the framework. This allows you to get inside the top. See the circles for the Velcro locations.
The elastic band torx screw is about 8" into the bowels of the top.
IMPORTANT: before removing the screw, put a towel into the compartment so if you drop the screw it doesn't fall into oblivion. Be sure the towel goes all the way out the window (you might get the screw out but drop it before you get it completely out - voice of experience). And don't forget to pull the towel out after you're finished.
Once you have the screw removed, the strap w/ elastic band looks like this.
Try moving the screw into a closer slot (like the arrow points to in the above pic).
HOWEVER, it is important not to make the band too tight as it will snap if there's too much tension on it. The problem is that band becomes less elastic as it ages and stretches, so you may find yourself between slots (too loose doesn't fix the problem, too tight breaks the band). What to do then?
Solution 2: Connect some bungee chord (aka shock chord) to the strap and use it instead of the elastic band. Here are the steps to perform this solution.
A. Buy some bungee chord at a local hobby store. I got mine at Hobby Lobby.
B. Cut a 12" section and burn the edges to prevent fraying.
C. Fish the looped chord thru the strap with a thin wire.
D. Measure 4 1/2" from the gray strap to the end of the loop. My measurement was with the loop pinched at the end (it's not pinched in the pic).
UPDATE: I've had better luck with 4 1/4".
Take a safety pin and pierce the strap, both pieces of chord, and the other side of the strap. Put the pin on the elastic band side of the strap since that's the side of the strap that's away from the canvas top. It may take a couple of attempts to get everything pinned properly.
E. I removed the small washer on the torx screw and replaced it with a 1" washer (10x1" shown or 1/8" x 1"). This gave the chord something to slip over yet have enough room to stay in place when tension is relaxed (top down). Others have simply tightened the chord down with the torx screw. I prefer my method as it allows me to keep the torx screw completely tightened as it was meant to be. - don't want it coming loose and falling out.
Worked great after several days. I may go back and hand sew the chord to the strap for added strength.
1989 928 S4 5 spd - black
Old 07-03-2016, 07:01 PM   #2
911monty's Avatar
That's an absolutely brilliant fix! Better than OEM. Thanks for posting!
Now if you can come up with a way to get the annoying thread piece of that screw that's rolling from side to side inside the bow of my top that's been there since my top replacement...... :troll: Although it does let me know when I have achieved .8 G.
Old 07-03-2016, 08:47 PM   #3
Multi-Boxer Driver
Deserion's Avatar
Thanks, Husker! This issue is present on my mom's '06, and now I can resolve that when I fix a few other items on it.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-04-2016, 05:50 AM   #4
Dr. Acula's Avatar
Very nicely done, Husker. Thanks for providing detailed photos and instructions.
I'd like to propose an even easier solution.
You can buy these on Amazon:
This is easy, no tools, quick, and adjustable.
Plus, it's cheap (4 for $13!) . Use two and give a pair to a fellow Boxster owner.
Here's what you do - Leave the original elastic in place. Clip one end of the Bed Band to the old elastic as close as possible to where it is attached to the screw. Clip the other end about halfway up the fabric triangle that holds the elastic to the top. Then adjust to the proper length. I adjusted mine where the unused tail portion was about 3.5 inches long (7 inches doubled over and roughly the length of what I can hold in my fist).
Works like a charm.
If the elastic shock cords tire out in a few years, you can either adjust them tighter or replace them with the spare pair that came in the set.
:dance:
Dr. Acula is offline   Reply With Quote
Old 09-23-2019, 03:46 PM   #5
Tension straps boxster
thanks Dr Acula the strap tensioners from amazon worked perfectly ~ I had duct taped and clip with garage stuff and didnt work the cheap clips from amazon worked great! and easy to do Q thanks
marc
marccuniberti is offline   Reply With Quote
Old 09-23-2019, 03:47 PM   #6
the straps from amazon worked perfectly compared to these other methods who WOULD use anything else for about 9 bucks and 10 minute my jury rigged mess was solved with these amazon clips great post thanks
Old 09-25-2019, 08:59 AM   #7
Hello,..do you fit the black triangle plastic pieces back in,..mine fell out and caused a bent arm..?? Thanks Frank
flmont is offline   Reply With Quote
Old 09-25-2019, 04:07 PM   #8
Finnegan's Avatar
Works like a charm.
:dance:
Ooooh! I'm gonna try this. Thank you!
Old 09-25-2019, 06:47 PM   #9
No issues with that using my method.
Old 09-02-2021, 06:46 AM   #10
The 986's have this problem. The issue I'm facing as I don't have the fabric piece that your elastic is attached too. The velcro strap on the convertible frame is all that remains of whatever used to provide the tension that guides the nylon beading into the aluminum channel. I'll have to figure something else out. I've watched other videos on YouTube and all of them have some fabric still attached to the nylon beading. Mine must have torn off at the seam--on both sides.
woodgeek is offline   Reply With Quote
Old 12-11-2024, 08:03 AM   #11
I think Porsche has tried many solutions to this problem. My 2004 is configured differently. The velcro strips have nothing to do with the tension of the top itself; rather, they fasten to the headliner and hold it in place. On my car the top beading is guided into its channel by another shorter bead that is secured to the top frame by its own channel. It is secured to this channel by a fixed bracket that apparently pinches this bead to hold it in place. There is a metal strap, secured by two screws, that appears to help hold this bead in place. Fortunately I caught mine early when the main bead came out of the channel. The top of the secondary bead had come out of its channel (for what ever reason the metal strap does not go all the way to the top of the bead) and the main bead was not held close enough to enter its channel when the top was closed.
pemorey is offline   Reply With Quote
Old 12-12-2024, 05:01 AM   #12
Mine still holding strong after 8+ yrs. I did both sides.
