Old 06-25-2016, 04:40 PM   #1
No oil pan gasket?
Is it true that there's no oil pan gasket? Just RTV?
SilverSSS is offline   Reply With Quote
Old 06-25-2016, 04:42 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
Correct and I believe Loctite 518 is one of the goo's of choice.
Old 06-25-2016, 04:58 PM   #3
steved0x's Avatar
Reinzosil is a good one, easy to use, waaaay easier than the loctite. Remember only a 1-2 mm bead of sealant is sufficient, too much can squeeze out inside and clog the oil.pickup.
Old 06-25-2016, 06:32 PM   #4
Mig
I was also surprised to find out there is no oil pan gasket.
I used RTV using the method, that YouTuber, Chris Fix describes. Basically, it's a stepped process, put the RTV on the sump plate, let it setup a bit, install the plate with just enough tightening to squeeze the RTV, let it cure a bit longer, and then tighten down.
This method worked really well for me. No leaks.
Here's a link to his video:
http://youtu.be/21CvanhKILA
Mig is offline   Reply With Quote
Old 06-25-2016, 11:44 PM   #5
Thanks Mig, and All... Thinking, wouldn't be very difficult to make a gasket. I might try that. Had some success with the rubber infused cork stuff before.
