Old 06-22-2016, 05:51 PM   #1
Chuck W.'s Avatar
Airbag Light On - Boxster Won't Start // SOLVED
I am starting this post in case anyone ever does a search for this issue. Yesterday I took the Boxster out after washing it and a half mile down the road the airbag light came on. Put the car in the garage and figured I need a tool to diagnosis the issue and reset the light - a Durametic was the direction I was headed in.
This afternoon I went out and the Boxster wouldn't start. Obviously, it has something to do with the airbag light. Back to the internet..... after another hour I came across a possible issue; Fuse Row E, Number 1.... also referred to as Terminal 86s. According to the paperwork, this fuse controls, "Instrument cluster, radio, central locking/alarm system, roll-over-sensor control unit (911 Cabrio), daytime running light (Canada).
I checked the fuse (7.5) and found that it was in fact blown. I replaced the fuse and the Boxster started! And, the airbag light was not longer illuminated!
Life is once again as it should be!!
1995 Porsche C4 Cab
Old 06-22-2016, 05:58 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
Any thought as to why it blew?
Old 06-22-2016, 07:28 PM   #3
Pdwight's Avatar
too much current ??
Just spit-balling here
I service Dialysis and RO equipment for a living....I see fuses blow for no good reason...even when you measure the current drain while in operation.....some times they go and you replace them and they just keep working....could be a "Iff'y" fuse
Old 06-23-2016, 07:00 AM   #4
Chuck W.'s Avatar
Perhaps.... I installed a 996 instrument cluster last year. The fact that this fuse has something to due with the "roll-over-sensor control unit (911 Cabrio)" leads me to believe this could be somehow related to the fuse blowing. When the airbag light illuminated I not only got the airbag warning it also showed "roll-over sensor" warning. Now, why it blew.... no idea. Pdwright could be right; it was just its time. I just hope it doesn't become an issue.
1995 Porsche C4 Cab
Old 06-23-2016, 11:53 AM   #5
jb92563's Avatar
I'd say that you had a combination of high Coronal Mass Ejections inducing a slightly higher current and a sub optimal fuse, just enough to push that fuse over its limit.
Space Weather Enthusiasts Dashboard | NOAA / NWS Space Weather Prediction Center
Old 06-23-2016, 05:48 PM   #6
rexcramer's Avatar
Damn space aliens.......
Old 06-23-2016, 06:21 PM   #7
Chuck W.'s Avatar
Haaaaaaaaaaaa..... never crossed my mind. Thanks.
1995 Porsche C4 Cab
Old 06-23-2016, 02:45 AM   #8
2003 Base 5-speed
grc0456's Avatar
Cheers for an easy fix! Thanks for posting.
Old 06-23-2016, 06:32 AM   #9
stelan's Avatar
Good info, thanks
stelan is offline   Reply With Quote
Old 06-24-2016, 07:12 PM   #10
Chuck W.'s Avatar
Ugh..... it brew again. The hunt for the electronic gremlin begins.
1995 Porsche C4 Cab
Old 07-05-2025, 08:14 AM   #11
What is the fuse position for the airbag/SRS?
I can't find it listed in the fusebox diagram.
Thanks,
Phil
PhilO is offline   Reply With Quote
