Old 05-14-2016, 12:52 PM   #21
heli coil time
So the saga continues...there was enough bolt sticking out originally to put a nut on, mig weld and back off. Not now! With all of the heating, drilling for an easy out, broken easy out in the bolt, more cutting, drilling, I am left with what is now a stripped hole in the head. So now to install a helicoil. I know about being careful with the depth and being extremely precise with the drill so the bit does not wobble and make too large of a hole. I have ready the thread mentioned about installing a heli coil. Any other tips?
Strangely, the heli coil thing does not really seem so scary after taking a torch to the car, cutting the bolt after the easy out broke, and then using a tap to slowly nibble away the last remaining bits of the bolt.
The bolt was on the row / side that is closest to the block.
The header bolt is really not a huge deal, the car drives fine, has a slight exhaust leak that would only be noticeable to a trained professional or a Boxster nut, and is a simple annoyance that bothers my anal-rentetive side enough that I will probably repair it.
What an adventure! On a good note, my engine cutting out issue turned out to be a simple MAF cleaning and reset of the ECU.
brewerbry is offline   Reply With Quote
Old 05-15-2016, 07:33 PM   #22
My tip, if you are thinking about heli-coiling, is to not use heli-coils, but use time-sert. They are a much higher quality product than heli-coil; a solid bushing insert that is thinner, so you won't need to drill out as large of a hole. The set will come with the proper size drill, counter-boring bit that will cut the proper depth counter bore at the outer edge of the hole, tap, and the installation tool that rolls bottom threads. You will need to figure out what depth bushing you want and order that.
++ TIME-SERT Official Threaded inserts for stripped threads, blown out sparkplugs,
Also, use anti-seize on new bolts to prevent this from happening again.
2001 Boxster
Old 05-16-2016, 10:02 AM   #23
Originally Posted by jcslocum View Post
Be very careful with the easy out. They are brittle like candy canes and very, very hard. If you break it off in there it will NOT drill out. Heat is your friend here, I will disagree with Ben above (he makes a great shifter!!) about the heating. Heat the surrounding head area to grow the hole larger not the bolt. Propane might not be hot enough but it is worth the try. Propane isn't hot enough to harm aluminum so heat for 2 min and try to loosen. Then addd 2 more min. Then let it cool down and start again. Do not heat with the easy out in there.
What size have you drilled it out to???
Do you have all of the other studs out already???
Stomski makes this kit for exactly this job:
https://www.stomskiracing.com/products/boxster-996-997-exhaust-bolt-repair-kit
Please heed his advice. Take the easy out now and throw it away. It will break off and you will not get it out. I learned that lesson with a moto. I broke off an easy out in the motor case. It cost me $750 to have a machine shop use a laser to vaporise the easy out.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-03-2016, 06:25 AM   #24
98 Arctic silver 986
tommy583's Avatar
Did you ever get this sorted out. I hope it ended well.
Old 06-03-2016, 09:18 AM   #25
all ended well
I was able to clean out all of the old bolt with a tap and the threads are strong enough for an original (new) Porsche header bolt to not only hold but get torqued down and not leak.
What a pain in the butt! I spent 2 hours very slowly and carefully cleaning out the hole with the tap and got lucky that I did not mar the original threads.
No more exhaust work on this car for me!!
Old 06-03-2016, 02:05 PM   #26
New carbon steel bolts ? Anti-seize?
After so many hours and $$$ of removing broken bolts we replace them with the same grade bolts?
Considering the frequency and expense of this issue ,it is surprising there isn't a little more interest in using the inexpensive, simple to install s/s stud kits mentioned earlier.
If intelligently installed, s/s studs will work perfectly for more many decades.Carbon steel bolts - not so much.
It would be poor engineering practice to use anti-sieze in this situation. It will complicate the choice of effective torque settings for the bolts because it acts as a lubricant. IMHO the correct grade of Loctite is better choice for exhaust bolts, studs & nuts( different grade for each) .
Loctite effectively deals with the conflicting issues of heat cycling, dissimilar materials, vertical installation, vibration and ability to remove the studs.YEMV.Suggest a visit to the Henkel tech section.
