Old 05-05-2016, 06:12 PM   #1
Need help removing side vent
Guys I need help removing the side vent on my 98. I've searched here and still can't get a clear answer on how this comes out. One of the louvers on mine is gone and want to replace just the black plastic piece. Thanks
1998 Porsche Boxster
1987 Porsche 944
1992 Mercedes-Benz 190E
2006 Mercedes-Benz C280 4Matic
Wizzie is offline   Reply With Quote
Old 05-05-2016, 07:11 PM   #2
I wish I had words of encouragement, but getting the vents out without breaking something is hard. Sometimes they come out without a fight, but most of the time they can be difficult. I have a busy weekend coming up, but I'll try and post a picture of the back side so you can see what you're dealing with. The black part of the vent has three tabs that slide into metal brackets attached to the vehicle. In the front leading corner of the vent there's a lip that holds it to the body. If you come straight out with the vent on that corner, you'll break that tab off. There might be a special tool or procedure for getting them out?
Woody
Old 05-05-2016, 07:46 PM   #3
Been awhile since I did this but the outer shroud slides sideways and off. That leaves the vents as you can see from pics. Fortunately mine didn't break. Good luck, pics should give you a better idea what you are dealing with.
Lapister is offline   Reply With Quote
Old 05-06-2016, 04:40 AM   #4
mikesz's Avatar
once you get the shroud off you can pull the vent gills towards you and it will pop out. I just replaced my 99 vents with those off a 03-04. I like the look
99 Porsche Boxster
Old 05-07-2016, 04:13 PM   #5
Got it ! Pretty easy too. The whole process took 10 minutes.
1987 Porsche 944
