Old 04-16-2016, 06:39 PM   #1
Ignition switch problem
Guys just bought my first Boxster today drove it home and went to start it again and it was stone dead. All the electrical accessories worked fine but it didnt even crank. I read that these switches were a common fail but would the problem be interminent ? I charged the battery and so far so good but I'm afraid to shut it off anywhere but home. I intend on replacing the switch next weekend.
Wizzie is offline   Reply With Quote
Old 04-16-2016, 06:42 PM   #2
How old is the battery and what's the voltage on a multimeter. Could be the ignition switch but it could also be the battery. Searching the forum will yield a lot of information on this topic.
Old 04-16-2016, 06:44 PM   #3
If it does turn out to be the switch (which I'd change anyway) It's a vw part , so check prices from vw dealers before you buy elsewhere .....
It's a common fault so they'll probably have one in stock , or if not vwna will have them in the warehouse for 3day delivery .
A bit fiddly but an easy job , but it helps if you're Harry Houdini
Ian c is offline   Reply With Quote
Old 04-16-2016, 06:47 PM   #4
Don't know its age it's an ac delco which I may just replace anyway. Running its putting out 13.99 volts
Old 04-16-2016, 06:50 PM   #5
That's what your alternator is putting out .
What does it give you after the engine has been off for an hour ?
Old 04-16-2016, 06:53 PM   #6
Don't know I will check that tomorrow & post the results. I checked it running to rule out the alternator.
Old 04-16-2016, 06:57 PM   #7
Good luck with it .
Probably just the porsche's way of saying hello to its new keeper by leaving interior light on or something .....
Old 04-16-2016, 07:02 PM   #8
Originally Posted by Ian c View Post
Good luck with it .
Thanks it has a few quirks and needs a few things but for an 18 yr old car I am very happy I finally own one.
Old 04-16-2016, 07:43 PM   #9
Yeah , congratulations !!!
They really are great little cars .
True porsche guys like them .
True car guys like them .
Anybody else's opinion of them I couldn't care less about
Old 04-16-2016, 07:47 PM   #10
You pushed the clutch to the floor? When I first got mine it scared the heck of of me a few times.
DWBOX2000 is offline   Reply With Quote
Old 04-16-2016, 07:50 PM   #11
Excellent post!
Its easy for your driver side mat to get bunched up under the pedals and not allow the clutch switch to engage.
Old 04-16-2016, 07:52 PM   #12
Pdwight's Avatar
Test your battery
Take it out...10 minutes max, take it to a Autozone, Oriley's etc....have them load test it...only to really trell.
Old 04-16-2016, 08:24 PM   #13
Not true .
Old 04-17-2016, 07:02 AM   #14
Pdwight's Avatar
Im talking about the battery, not the switch.
Load testing places a high current drain across the output of the battery while monitoring what voltage it can maintain at a high load....if you have a dead cell this will show it. He already stated his dwell voltage to be over 13V so he does not have an open or shunted cell
Old 04-17-2016, 04:37 PM   #15
The old carbon pile load tester is O.K. but there are more sophisticated electronic testers that show "State of Charge" and other condition issues.For example :
Amazon.com: CTEK (56-925) 12 Volt Battery Analyzer: Automotive
Old 04-17-2016, 05:08 PM   #16
Sitting for an hour reads 12.79V
Old 04-17-2016, 05:11 PM   #17
Pdwight's Avatar
Agreed
But not for free, why buy the cow when you can get the milk for free...this is a quick easy test and it will tell you if your battery is at the end of it's life
Old 04-17-2016, 06:54 PM   #18
So on the surface you don't have a problem .
Battery is good and alternator is charging .
Next test would be a draw whilst standing idle , but if you're going out enjoying the new car , you probably won't experience much sitting idle
