Old 04-13-2016, 06:29 PM   #1
Muskoka Minute's Avatar
Is This Normal
I finally got to see what my engine looks like.
Here is what I found.
The engine is dirty but dry. Except on this one part.
Would a bad/going AOS unit do this? If not what?
The dealer says that this is normal and all Boxsters have some weeping.
Is this Bull S**T or true?
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
Old 04-13-2016, 06:42 PM   #2
Clean the engine and see what comes back. You can't know what's old and what's not. That's my advice.
Old 04-13-2016, 06:42 PM   #3
i think you just have a dirty motor. If you had an AOS problem, you'd have smoke coming out exhaust and find it hard to open your oil filler cap with car idling.
Clean the motor off, drive it for a few months and take another look. I think you're good to go.
Old 04-13-2016, 11:11 PM   #4
Steve Tinker's Avatar
The oil could possibly from the power steering vent - check the level to make sure its not low....
2001 MV Agusta F4.
Old 04-13-2016, 11:20 PM   #5
Multi-Boxer Driver
Deserion's Avatar
It's definitely not an AOS issue. My engine bay looked similar until I cleaned it off, so I'd say it's usual.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 04-14-2016, 01:33 AM   #6
Looks normal to me. At least for a box with more than 80k and has never been cleaned.
Woody
Old 04-14-2016, 04:10 AM   #7
Project Addicted
jcslocum's Avatar
AOS puts oil on the INSIDE not the outside. It is odd that it is all on the center section of the intake tho...
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 04-14-2016, 04:27 AM   #8
Mine looks the same in that area. Never really thought much of it.
Old 04-14-2016, 04:34 AM   #9
Thanks Guys.
That puts my mind at ease.
I was thinking the worse.....and so was my wallet.
Have a happy Boxtering day!
Cheers! Bart
Old 04-14-2016, 12:48 PM   #10
Don't fret the AOS...it's a ~$125 part and easily replaced on 2003-04 Boxsters without going underneath the car.
I did my buddies 03S about a month ago. I'd never done an AOS and it took me 2 hours start to finish. Most of the first thirty minutes was just locating the tubes and bolts that needed to be removed. It looked daunting at first but was really a piece of cake.
Old 04-14-2016, 01:12 PM   #11
2002 s
My engine looked the same when I bought the car in 2014 with 34,000, cleaned and looks great.
eallga72 is offline   Reply With Quote
Old 04-14-2016, 01:16 PM   #12
geraintthomas's Avatar
I hate green cars, apart from yours - that's beautiful.
Anyway back on topic, it's normal. Mine was the same before I cleaned it.
Porsche Boxster S Type 986
Old 04-14-2016, 01:33 PM   #13
JRide's Avatar
Muskoka- Mine looked similar.
ellga- Great pic of your car!
JRide is offline   Reply With Quote
Old 04-14-2016, 02:02 PM   #14
njbray's Avatar
It seems like everyone has a damp spot around the power steering reservoir.
I have cleaned it, replaced the cap o-ring & checked the connections - and I still have the damp patch!
Old 04-14-2016, 02:24 PM   #15
2003 s
No matter what color it puts a smile on your face
Old 04-14-2016, 04:51 PM   #16
Yea, pretty sweet looking car. What kind of wax etc... do you use to have it shine like that?
2003 Boxster S
2004 Carrera Cab
Myoung73 is offline   Reply With Quote
Old 04-14-2016, 04:55 PM   #17
Bought my 03s last year, haven't had a look at the engine yet but that should change soon. I know I will probably want to clean it, but have to admit spraying water on the engine just makes me nervous!
2003 Boxster S
2004 Carrera Cab
Old 04-14-2016, 05:33 PM   #18
What do you folks use to clean your engines? The engine in my 02 base with 63k on the clock looks similar.
Richardbruce is offline   Reply With Quote
Old 04-14-2016, 06:34 PM   #19
X2
I was going to ask the same question.
Thanks for all the input guys.
Old 04-14-2016, 07:58 PM   #20
I am my own mechanic....
Timco's Avatar
I used orange / citrus grease cutter, then hose. Mine looks very clean.
'08 VW Touareg T-3 wife's car
